Blender F.A.Q (Last Updated: 2025 Jan 09 9:55 pm)
If you don't have time to learn to setup one of the network rendering systems you can just use the command line version of Blender to render a few frames on each computer and manually queue up more when each computer is done.
http://wiki.blender.org/index.php/Manual/Rendering_From_Command_Line
If you have a little money you should use this service:
http://www.respower.com/
Or if you have time you an learn to setup one of these systems:
http://www.blendernation.com/2006/12/13/more-distributed-rendering-options/
Thanks for the info. I looked back and apparently I was mistake, it's not a built in feature. Bryce has an included app for rendering over a network which I've used before.
I'll try to set one up.
Red
Reddog9
Tutorials, Samples and Models
www.blender3dclub.com
You're welcome. Just in case someone else wants to try the quick and easy way:
I used this type of command line before:
blender -b file.blend -o "C:RENDERSMOVIENAME" -F JPEG -s 001 -e 050 -a -x 1<br></br><br></br>and on the second computer:<br></br><br></br>blender -b file.blend -o "C:RENDERSMOVIENAME" -F JPEG -s 051 -e 100 -a -x 1<br></br><br></br>and so on depending on how many computers you have. <br></br>When one finishes just repeat the command with different frame numbers. <br></br>If one computer is slow you can just kill the process, re-assign the leftover frames and take whatever frames it has already done.
I know this is an old thread, but I've started using a Blender version called verse-blender. It's listed on Blender.org in the Download section. Under Scene < ANIM, click Render Daemon. There's also a script called Farmerjoe that will also give net render capability. You'd have to do a web search for it, though.
It is better to do one thing well, than to do many things and excel at nothing.
Anyone no how to set this up? I was going to work on a music video, and thought I'd pan some of the work load off on my lap top. I've searched the Blender docs but have been unable to find it. I'm sure I saw this listed as a Blender feature somewhere.
Scott
Reddog9
