Fri, Jan 10, 7:28 PM CST
Renderosity Forums / Blender
Welcome to the Blender Forum
Blender F.A.Q (Last Updated: 2025 Jan 09 9:55 pm)
Welcome to the Blender Forum!
   Your place to learn about Blender, ask questions,
   exchange ideas, and interact with the other Blender users!
   Gallery | Freestuff | Tutorials
Visit the Renderosity MarketPlace. Your source for digital art content!
Subject: Network Render?
Reddog9 ( ) posted Wed, 03 October 2007 at 5:56 PM · edited Mon, 23 December 2024 at 7:23 AM
Anyone no how to set this up?  I was going to work on a music video, and thought I'd pan some of the work load off on my lap top.  I've searched the Blender docs but have been unable to find it.  I'm sure I saw this listed as a Blender feature somewhere.
Scott
Reddog9
Tutorials, Samples and Models
www.blender3dclub.com
l3la ( ) posted Mon, 08 October 2007 at 1:27 AM
If you don't have time to learn to setup one of the network rendering systems you can just use the command line version of Blender to render a few frames on each computer and manually queue up more when each computer is done.
http://wiki.blender.org/index.php/Manual/Rendering_From_Command_Line
If you have a little money you should use this service:
http://www.respower.com/
Or if you have time you an learn to setup one of these systems:
http://www.blendernation.com/2006/12/13/more-distributed-rendering-options/
Reddog9 ( ) posted Mon, 08 October 2007 at 8:56 PM
Thanks for the info.  I looked back and apparently I was mistake, it's not a built in feature.  Bryce has an included app for rendering over a network which I've used before.
I'll try to set one up.
Red
Reddog9
l3la ( ) posted Tue, 09 October 2007 at 6:11 PM
You're welcome. Just in case someone else wants to try the quick and easy way:
I used this type of command line before:
blender -b file.blend -o "C:RENDERSMOVIENAME" -F JPEG -s 001 -e 050 -a -x 1<br></br><br></br>and on the second computer:<br></br><br></br>blender -b file.blend -o "C:RENDERSMOVIENAME" -F JPEG -s 051 -e 100 -a -x 1<br></br><br></br>and so on depending on how many computers you have. <br></br>When one finishes just repeat the command with different frame numbers. <br></br>If one computer is slow you can just kill the process, re-assign the leftover frames and take whatever frames it has already done.
DramaKing ( ) posted Tue, 06 November 2007 at 5:30 PM · edited Tue, 06 November 2007 at 5:34 PM
I know this is an old thread, but I've started using a Blender version called verse-blender. It's listed on Blender.org in the Download section. Under Scene < ANIM, click Render Daemon. There's also a script called Farmerjoe that will also give net render capability. You'd have to do a web search for it, though.
It is better to do one thing well, than to do many things and excel at nothing.
