Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 02 9:25 am)
The Animation Palette? This provides a dope sheet style layout of the animation keyframes. Select the object, fold it if necessary. Then drag a box across the object's keys and across all of the frames. Hit the Delete key. This will delete the keys for all body parts and all animated parameters.
C makes it easy to shoot yourself in the
foot. C++ makes it harder, but when you do, you blow your whole leg
off.
-- Bjarne
Stroustrup
Cool, Thanks. That did just what I needed
If I want to delete keyframes for one object is there a faster way then using the graph and deleting each angle, movement, resizes, etc. individually?
