Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 2:22 am)
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=129657
http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=129657This is what Steve posted at the Poserforum a while back for the tile trick in UVMapper. I saved it. Okay, you're mapping a WALL So this should work. Open the prop in UVMapper from an OBJ file Select the geometries then EDIT/NEW UVMAP/PLANAR In the dialog box select DON'T SPLIT. The map should probably be allong the Z Axis as well. Hit OKAY. Hit the * key. Once, to tile 4 times. Twice to tile 16 times. Hit the HOME Key (why is unimportant, just do it) Hit ENTER Now go to File/SAVE MODEL Save the model, and import into poser.
Does anybody knows how to attached wallbricks to props. With only few bricks I need to tile them to fit wall. Thanks for helping
