Sat, Feb 15, 10:19 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 15 9:24 am)
Subject: Textures for props
bb2000dk ( ) posted Fri, 01 June 2001 at 12:51 PM ยท edited Sat, 15 February 2025 at 10:18 AM
Does anybody knows how to attached wallbricks to props. With only few bricks I need to tile them to fit wall. Thanks for helping
JeffH ( ) posted Fri, 01 June 2001 at 2:54 PM
I think there's a trick you can do with UVmapper to get an OBJ to tile the texture. The thread is in here somewhere, I'll have to hunt it down.
igohigh ( ) posted Fri, 01 June 2001 at 2:55 PM
Normally a "Brick Wall" would be done in Poser with a solid flat obj and the brick "texturing" is created using a BUMP map. To tile separate brick objects you are in for a HUGE file!
JeffH ( ) posted Fri, 01 June 2001 at 3:06 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=129657
Lovely Lady ( ) posted Fri, 01 June 2001 at 3:46 PM
This is what Steve posted at the Poserforum a while back for the tile trick in UVMapper. I saved it. Okay, you're mapping a WALL So this should work. Open the prop in UVMapper from an OBJ file Select the geometries then EDIT/NEW UVMAP/PLANAR In the dialog box select DON'T SPLIT. The map should probably be allong the Z Axis as well. Hit OKAY. Hit the * key. Once, to tile 4 times. Twice to tile 16 times. Hit the HOME Key (why is unimportant, just do it) Hit ENTER Now go to File/SAVE MODEL Save the model, and import into poser.
BillyGoat ( ) posted Fri, 01 June 2001 at 9:22 PM
THANK YOU! I've been going nuts with the same problem. No matter how big I make the 'brick wall texture' it still stretches like mad. I'm talking a 6 meg sized textures...
