Wed, Dec 4, 3:46 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 04 2:40 pm)
Subject: extract component from a Poser model, modify and reload into Poser maintaining h
crocodilian ( ) posted Thu, 18 October 2007 at 5:59 PM · edited Wed, 04 December 2024 at 3:39 PM
Hi, I wondered if anyone could enlighten me on workflow. I'm extracting a part of a wagon, the hitch, from the Daz Boundless Journey model, to modify it in Lightwave into a more complex harness. Is there a way to extract this component, modify it externally, and then bring it back into Poser without messing up hierarchy, boning, etc? thanks in advance. I'm exporting as LWO, and can save in any Lightwave supported format -- I've generally used OBJs when going back into Poser.
Gareee ( ) posted Thu, 18 October 2007 at 7:43 PM
Don't bother to export in lwo.. just load the original obj they provided into lightwave.
Just make sure you don;t accidentally write over it, and remember that you MUST apply a map to all materials in order for lightwave to retain the UV info when you export the obj back out.
crocodilian ( ) posted Thu, 18 October 2007 at 7:49 PM
Quote - Don't bother to export in lwo.. just load the original obj they provided into lightwave.
Thanks for this.
And if I want to substitute the modified version in the old object hierarchy? What should I do? I don't want to overwrite the original
Gareee ( ) posted Thu, 18 October 2007 at 7:54 PM
just copy the cr2, and change the obj name in it in a text editor to your new obj's name.. and note you need to do it in TWO places, not just one.
markschum ( ) posted Thu, 18 October 2007 at 9:49 PM
If you do a lot of mods that is gonna mess up the grouping for the rigging isnt it . ?
Gareee ( ) posted Thu, 18 October 2007 at 10:16 PM
It really depends. I twist polys until they scream, but then I've been doing if for 4 years now, and I know just how much I can torture them before they expire.
Plus keep in mind, if you add or delete polys, it'll bereak any morphs that already exist, and if you add polys, you need to make sure that you uv map them, AND make sure they have the same group names as the part they are associated with.
Also keep in mind that objs are copyrighted, so if you were thinking of doing an expansion, and redistributing it, you'd have to rtencode it against the original product.
Some vendors also do not allow cr2 redistribution, so that would cause you issues as well.
Just really depends on if this is for YOU, or for others.
crocodilian ( ) posted Thu, 18 October 2007 at 10:39 PM
Hey Gareee, thank you for the very complete answer! This is just for me, so redistribution/intellectual property issues aren't a problem, but i appreciate you alerting me to the concern.
Gareee ( ) posted Thu, 18 October 2007 at 10:47 PM
Cool.. in that case, beat the hell out of it.. that's the best way to figure out what you can and cannot get away with.
Also, if you add additional parts and need to uv map them, keep in mind lightave can keep track of miltiple UV maps, so you can unwrap your new stuff and use as much uv space as you need.
save out the additions separately, and you can get tyhe uv maps for those very easily, and then toss away that saved additiona object.
crocodilian ( ) posted Fri, 19 October 2007 at 1:42 AM
Quote - Also, if you add additional parts and need to uv map them, keep in mind lightave can keep track of miltiple UV maps, so you can unwrap your new stuff and use as much uv space as you need.
I'm not following this. Are you saying that if I take a component, which had previously had to share a texture space with the rest of the Poser object, and export it out, I can give it its own UV mapping, and reimport it into Poser?
Gareee ( ) posted Fri, 19 October 2007 at 11:41 AM
No. you can have multiple uv maps for an object. getting the template from that mess can be a pain.
Save JUST the new parts, JUST for the prupose of getting thier template easily, and make sure they all have new materials.
the Uvs will be the same in the original obj with the additions, as the exported additions only.
You coul ddick around in uv mapper to hide everything else and then make a template, but why bother if there is a simpler method?
crocodilian ( ) posted Fri, 19 October 2007 at 12:20 PM
Quote - Save JUST the new parts, JUST for the prupose of getting thier template easily, and make sure they all have new materials.
Oh. This is subtle, and I hadn't thought of it. Thanks-- gold star tip, that!
Gareee ( ) posted Fri, 19 October 2007 at 2:01 PM
Sometimes easy stuff is overlooked...;)
