Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2024 Nov 08 7:09 am)
But... would it require a lot of computer power to use in animation, you think ?
We will soon be testing on other computers and one of them is a AMD with ~1.5 Ghz and 2 Mb ram. I will post the results as soon as it is done.
Meanwhile, here is a picture of the darker bear which will be in the same pack.
Quote - He looks really nice - if I may ask how did you manage to achive this ?
It is mainly a couple of things:
On top of this it is the detailed styling which I do to avoid "exploding hair" and to make it follow the texture map (if I use a texture map on the object) and to simply style some areas for example a bit longer fur at places.
Well, I think that sums it up.
This does not happen to every object, for example the furred rat never had this that is why he could be released. But for some reason some objects behave very bad with fur.
No worries though I will go on with the other animals and in line is the bear from EF Wildlife series. There are freebies coming up too but this is a secret for now. :sneaky:
You released a furred rat? Eeeek eeeeek
I aim to update it about once a month. Â Oh, and it's free!
Quote - Do you think you will ever do a pup? Sharen
Absolutely Sharen!
And when e-frontier get the hair room issues fixed (probably in a patch according to tech) I hopefully will not have to spend so much time on ojects that turn out they don't work when done.
Maybe you remember the MilDog pup I made once upon a time? I still have it on my list but will probably have to redo it from scratch because of the Poser "issues".
We'll see what happens.
I am pleased to say it will not be months or years before he is released only the testing on other machines is left.
Tell me what you think.
