Sun, Jan 26, 2:04 AM CST
Subject: Wet and Dry ground Nodding Problem (P6)
Robo2010 ( ) posted Sun, 21 October 2007 at 9:03 PM · edited Fri, 24 January 2025 at 8:20 PM
For months (years actually), I tried to accomplish a wet and dry ground together. I gave up along time ago, and then tonight I thought I would try again. I thought a reasonable transparency map (image) would do it, but I was unsuccefull. So, it is time to ask. Maybe someone can come in a give a try or have something to help solve my problem. Partially wet, and partially dry ground in some areas.  I gave an image example what I am trying to accomplish.
Miss Nancy ( ) posted Sun, 21 October 2007 at 9:23 PM
maybe plug a b/w cloud node into the reflection channel.
Conniekat8 ( ) posted Sun, 21 October 2007 at 9:35 PM
Yeah, a cloud node in the specularity and reflection nodes.
Also, a reverse of that in a bump node. See how there's almost no bumps visble in shiny parts.
pjz99 ( ) posted Sun, 21 October 2007 at 9:41 PM
^^ sounds very reasonable, I would have suggested the same - something to mask the areas where you want low specular values, although be aware if you use a clouds node it will be random; if you really want it "how you want it" then make a specular or reflection map.
My Freebies
Robo2010 ( ) posted Sun, 21 October 2007 at 9:54 PM
A cloud nod is a great idea, although I am working on it now (many attempts already), still struggling. I do have a texture map already in use, along trying to use the B/W cloud with it. Noise is also needed to help make the ground (road), and I have that already in the bump. So, I guess you can see where I am going with this. I did have a png (grainy transparency image) in use, but after reading some pointers, I removed it. Still trying,
Robo2010 ( ) posted Sun, 21 October 2007 at 10:38 PM
Well, getting somewhere slowly. I will continue this tmrw night. If you notice on image example (Post #1), that some part are more reflective, and other areas are not.
MegaJax ( ) posted Mon, 22 October 2007 at 7:28 AM
Have you tried using two ground objects? one for the water and one for the dry ground?
I would make the water one flat and with a high reflective setting and use a bump map on the ground one to rase parts out of the water with a less reflective setting. Then just move the ground one up through the water untill you get the desired result.
bagginsbill ( ) posted Mon, 22 October 2007 at 9:31 AM
Attached Link: Pavement Puddles Shader
Here's my version. I used a Fractal_Sum to generate the puddles. I used a Spots node to make the ground texture. You could use a photo instead.
My ground was scaled to 4000%. You may have to adjust the scale of some nodes to match your ground or road prop.
You can get the Poser material file at the link.
Robo2010 ( ) posted Mon, 22 October 2007 at 9:42 AM · edited Mon, 22 October 2007 at 9:45 AM
OMG!! Just amazing! Will have to look into this when I get home.
Conniekat8 ( ) posted Mon, 22 October 2007 at 12:37 PM
Fabulous work Bagginsbill!
Robo2010 ( ) posted Tue, 23 October 2007 at 10:24 AM
I could have never figured this out on my own after playing around with the shaders. I am wondering how to change the puddle sizes. I would like em larger. I am having problems doing this.
bagginsbill ( ) posted Tue, 23 October 2007 at 12:13 PM
Change the scale values in the Fractal_Sum node. Bigger is bigger.
