Sat, Jan 11, 6:53 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 10 10:15 am)
Carrara Free Stuff here.
Subject: Rolling up paper animation
morphious ( ) posted Mon, 29 October 2007 at 11:01 AM · edited Sat, 11 January 2025 at 6:46 AM
Does anyone know how to animate a peice of paper rolled up, then unrolling? Thanks.
whkguamusa ( ) posted Mon, 29 October 2007 at 5:24 PM
file_392065.txt
Try this: Rename the attached file from roll-up.txt to roll-up.car and load it into Carrara. It is a grid with a bend modifier set to 600% at the start and 0% at the 2 second mark.
wayne k
guam usa
the file is Version 6 of Carrara, I can upload a version 5 or 4 if you need.
whk
Miss Nancy ( ) posted Mon, 29 October 2007 at 11:39 PM
thx fr the file, wayne it looks like this in c6proX Image Hosted by www.postmyimage.com
whkguamusa ( ) posted Tue, 30 October 2007 at 12:27 AM
For extra credit animate the limits sliders of the bend deformer
wayne k
guam usa
morphious ( ) posted Tue, 30 October 2007 at 6:51 AM
Thanks, I tried that, but didn't get the same result as the Second one you uploaded. I'll give it a try. Thanks a bunch :)
morphious ( ) posted Tue, 30 October 2007 at 6:57 AM
The file won't allow me to change it's file type in the properties. Any suggestions? I have full permissions too.
morphious ( ) posted Tue, 30 October 2007 at 7:00 AM
Also, I don't see this "first" and Second" mark in the bend and twist modifyer box?
whkguamusa ( ) posted Tue, 30 October 2007 at 5:18 PM
file_392176.txt
Not sure what you are asking. Here is the file that shows the second effect. It is a Carrara 6 file - you should be able to just change the .txt to .car and it will run in Carrara. If it still won't work let me know.
wayne k
guam usa
bwtr ( ) posted Tue, 30 October 2007 at 7:21 PM · edited Tue, 30 October 2007 at 7:22 PM
Morphious. About the name change. I just click on the (.txt) file, select Rename, and then just retype the name---- Rollup.car.     You should get a little dropdown asking your permission to allow the change, which you do!
Have you tried that?
bwtr
bwtr ( ) posted Tue, 30 October 2007 at 7:49 PM · edited Tue, 30 October 2007 at 7:49 PM
Wayne.
The rollup2 file does not download with the .txt suffix and will not convert to .car?
An odd one?
bwtr
whkguamusa ( ) posted Tue, 30 October 2007 at 7:57 PM · edited Tue, 30 October 2007 at 7:57 PM
Attached Link: http://3dsplash.com/WayneK/test/rollup2.zip
> Quote - Wayne. > > The rollup2 file does not download with the .txt suffix and will not convert to .car? > > An odd one?
Must be the full moon and it being Halloween here today.
Lets try the attached link instead
wayne k
guam usa
bwtr ( ) posted Tue, 30 October 2007 at 8:30 PM
We don'thave Halloween. Blame the NZers---the big white cloud drifted up your way and confused you---too/also/as well as!!!!!!
It's great when people live in proper time zones!
bwtr
Miss Nancy ( ) posted Tue, 30 October 2007 at 10:50 PM · edited Tue, 30 October 2007 at 10:51 PM
o.k., thx fr the zip, wayne. looks like this in c6proX Image Hosted by www.postmyimage.com
morphious ( ) posted Wed, 31 October 2007 at 8:19 AM
No worry, I finally figured how to do it using the constraint sliders. Thanks.
