Try contacting Netherworks and asking if they can do anything for you as they made the 'Poser 5 MAT Writer'
Edit: They sell a newer version on their webstie
If you're using Poser 6 or 7, you can save a Material Collection direct to the Material Room. It works in the same way as a MAT pose except you access them from the Material Room rather than the Pose Library.
Select your prop, then click the + at the bottom of the Materials library. Select Material Collection from the dialog box, give it a filename and you're good to go.
BTW, no prop will respond to a MAT pose or Material Collection unless it's parented to something. Nothing you can really do about that, it's just the way Poser works.
If you have Poser 6 or 7, you can do it simply by using the material room & a text editor.
In Poser save the MAT as a material collection in the Material room. Then...
Open the mc6 file in a text editor
Replace the top few lines that look like this...
version
number 7
mtcollection
with this ...
version
number 4.01
actor prop name
To get the prop name open the prop file in the same text editor & it will be listed at the top next to the word prop
Eg.
version
number 4.01
prop hat:1
So you would end up with....
version
number 4.01
actor hat:1
The best & most beautiful
things in the world cannot be seen nor touched... but felt in the
heart.
Helen Keller
My
Gallery
My
Freebies
My
Store
For some reason, my mind is blank. :-) I know I have created props and saved them as "smart props" ie...a hat for Vicky 4. Then saved them to my figures library so that I could use MAT Pose Edit to create texture injection files. Now I can't save the props as figures. No plus sign at the bottom and MAT Pose Edit won't save a proper injection file for a texture from the prop file. HELP! :-) Thanks for any ideas. I see other props done by others that you can't save as figure files either, but somehow they did mat injection files for texturing in the Pose folder.
Kathie Berry
Admin/PlanIT3D
Some painters transform the sun into a yellow spot.
Others transform a yellow spot into the sun.
--Pablo Picasso-
