Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 6:55 am)
Go for the ProPack version. The difference is in the bump maps. Poser 4 uses red/green BUM files, all other versions onward generally use greyscale JPG for bumps.
That said, Poser 6 (and I guess 7) can use BUM files but they are generally not used now because they're larger files than the greyscale versions. Word of warning, though - greyscale maps should be plugged into the Bump channel, not the Gradient_Bump channel. Chances are the default MAT poses will connect them wrong.
Hi Colin_S,
Poser 4 used the .rsr file for the thumbnail image in the Library.
Pro Pack started using .png files for thumbnail images.
You don't really need either one because ...
If the thumbnail image i.e., .rsr or .png, is missing, you will see the little shrugging guy in the Library.
How to make a new thumbnail image.
Poser will create a new thumbnail image for the Library.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Poser 6 & 7 will automatically create PNG files for your library using the old RSR files, not sure about Poser 5.
Quote - I can get P5 to run for way more than 5 seconds...just ask it to find a texture that's not in the right place...;)
PP is excellent !!!
I still use it a lot for Poser creations. It´s fast and renders are fast and clean (attention: the shader tree settings aren´t rendered, just the simple settings are loaded to be rendered).
PP is excellent!
Plus3D
My freebies at Renderosity -
CLICK HERE :)
**Lucifer_The_Dark
**I can safely say with using P5 I have never had that prob.
If I did it was because the textures were either missing or not
the right path in the file it's self which, is usually the problem.
If the path is wrong, Poser will not find it. I fix that by editing
the file and changing the path in notepad. Thats just me
tho. I don't mind taking the time to edit a .cr2 or a prop file.
Can someone tell me what to do when an older piece of freestuff installs as P4 and PP?
I'm on P7, and the only difference I can see is the .rsr in P4 but not in PP.
Is it something to do with the MATs? Which one can I delete?
