Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 02 9:25 am)
To have that chair texture in front of the figures in the scene is very odd. I think something else is happening here. Have you used the atmosphere node at all? Applied any textures to lights? Used a plane to simulate a smoky atmosphere?
Also, what is the yellow strip in front of the seated figure?
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
Selecting "Use Background Shader Node" didn't help.
I checked the atmosphere and the lights and none have a texture. The only plane is the yellow strip. It's a blanket for the baby that isn't clothified yet. The texture isn't realy in front of the figures. The dragon it slightly transparent. Sorry I guess I should have mentioned that.
Oh I see, that makes sense.
This is really strange. What's the name of the chair texture? It's not the same name as the background, is it? That's the only thing I can think that would make it do this.
Have you tried hitting "reload textures" on the Render menu?
"you are terrifying
Shire
I double checked the texture names and they aren't even close to being similar. I tried reloading the textures and that didn't help. I also tried changing the background texture to something totally new and it was still messed up.
OK. At this point I think I'd try the following.
"you are terrifying
Shire
Tried those. Still not working right. Thanks for the help. I guess I'm off to the e-frontire site to see if I can stump them now too.
Backgrounds in Poser are awkward. It's more reliable to set up a background prop--usually the square primitive--and apply the texture to that. Or combine foreground and background in postwork. Also, check your settings for the ground material. You look to have the shadowcatch box checked. [Use the render over black option and save as a PNG: this will give you an alpha-channel mask for your foreground object.]
AntoniaTiger that's what I did. I used skydome to finish the image. And I tookcare of the shadows too. The image had only been half done when I posted, but thatnks for the advice
