Poser - OFFICIAL F.A.Q (Last Updated: 2024 Jul 04 1:52 pm)
To have that chair texture in front of the figures in the scene is very odd. I think something else is happening here. Have you used the atmosphere node at all? Applied any textures to lights? Used a plane to simulate a smoky atmosphere?
Also, what is the yellow strip in front of the seated figure?
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
Selecting "Use Background Shader Node" didn't help.
I checked the atmosphere and the lights and none have a texture. The only plane is the yellow strip. It's a blanket for the baby that isn't clothified yet. The texture isn't realy in front of the figures. The dragon it slightly transparent. Sorry I guess I should have mentioned that.
Oh I see, that makes sense.
This is really strange. What's the name of the chair texture? It's not the same name as the background, is it? That's the only thing I can think that would make it do this.
Have you tried hitting "reload textures" on the Render menu?
"you are terrifying
Shire
I double checked the texture names and they aren't even close to being similar. I tried reloading the textures and that didn't help. I also tried changing the background texture to something totally new and it was still messed up.
OK. At this point I think I'd try the following.
"you are terrifying
Shire
Tried those. Still not working right. Thanks for the help. I guess I'm off to the e-frontire site to see if I can stump them now too.
Backgrounds in Poser are awkward. It's more reliable to set up a background prop--usually the square primitive--and apply the texture to that. Or combine foreground and background in postwork. Also, check your settings for the ground material. You look to have the shadowcatch box checked. [Use the render over black option and save as a PNG: this will give you an alpha-channel mask for your foreground object.]
AntoniaTiger that's what I did. I used skydome to finish the image. And I tookcare of the shadows too. The image had only been half done when I posted, but thatnks for the advice
![](https://live.cdn.renderosity.com/forum/threads/2719108/file_392614.jpg)
The image on the left is a render of the one on the right. I want to have the clouds as the background bu when I render it, I get either the texure image for the chair or I get a pink background with a peel texture. I'm working in Poser 7and using fire fly as my render engine. I've tried both "render over current BG shader" and "render over Backgorund picture" My setting is automatic one mark less that final render. Is this a bug in poser 7? Is my image corrupt? Did I mess up on some settings?Available on Amazon for the Kindle E-Reader Monster of the North and The Shimmering Mage
