Mon, Jan 27, 3:32 AM CST
Subject: Problems with Poser 7
BladedSoul ( ) posted Wed, 07 November 2007 at 2:17 PM · edited Mon, 27 January 2025 at 3:28 AM
2 problems I seriously need answers to.
  1. How do I do a large sized render? Not just a small in-program one, but a large size one.
  2. I'm planning on getting a new computer soon. If I install Poser 7 on there, will it work?
~Hutton~
FrankT ( ) posted Wed, 07 November 2007 at 2:22 PM
  1. Define "Large"
  2. What spec is the new machine
Give us something to work with :)
My Freebies
Buy stuff on RedBubble
BladedSoul ( ) posted Wed, 07 November 2007 at 2:24 PM
I mean Large as in, I dunno, 700 x 700 for example.
And I don't mean as in specs. I mean involving registration issues. If i've already used the code, will it work again, that's what I'm asking.
~Hutton~
Paloth ( ) posted Wed, 07 November 2007 at 2:26 PM · edited Wed, 07 November 2007 at 2:27 PM
1. How do I do a large sized render? Not just a small in-program one, but a large size one. Look atop your screen where it says 'Render.' 'Render size' is in the menu. Set the dimensions.
MegaJax ( ) posted Wed, 07 November 2007 at 2:31 PM · edited Wed, 07 November 2007 at 2:37 PM
700x700 isnot that large, I render at around 2000 to 3000 -on the menus at the top  Click on Render - render dimentions (or size, can't remember which) then you can change the size and resolution
Edit: and if the finished image is to be printed a dpi 0f 300 or more
Miss Nancy ( ) posted Wed, 07 November 2007 at 2:55 PM
the code may work again, but there may be problems if connected to a network with another machine containing poser7, as well as problems trying to register copies of the app from other machines.
svdl ( ) posted Wed, 07 November 2007 at 4:11 PM
I've got Poser 7 installed on 2 machines - my scene creation workstation and my rendering workstation. The rendering workstation needs an installed Poser for Vue to work with.
I can import and render Poser scenes in Vue on the render station while working with Poser on the scene station. The machines are connected over the LAN.
Poser does not complain when I do this. It only complains when I fire up Poser on both workstations - as expected, since I only have one P7 license.
I work from the analogy "use it as a book" that e-frontier itself uses when explaining the terms of the license. Installing Poser on multiple machines is no problem licensewise, as long as only 1 copy is running at any time.
So Poser 7 will work when you install it on your new computer - as long as your old computer doesn't RUN Poser 7 at the same time. But there's no need to uninstall Poser from your old machine.
My gallery   My freestuff
