Define "Large"
What spec is the new machine
Give us something to work with :)
My Freebies
Buy stuff on RedBubble
1. How do I do a large sized render? Not just a small in-program one, but a large size one. Look atop your screen where it says 'Render.' 'Render size' is in the menu. Set the dimensions.
I've got Poser 7 installed on 2 machines - my scene creation workstation and my rendering workstation. The rendering workstation needs an installed Poser for Vue to work with.
I can import and render Poser scenes in Vue on the render station while working with Poser on the scene station. The machines are connected over the LAN.
Poser does not complain when I do this. It only complains when I fire up Poser on both workstations - as expected, since I only have one P7 license.
I work from the analogy "use it as a book" that e-frontier itself uses when explaining the terms of the license. Installing Poser on multiple machines is no problem licensewise, as long as only 1 copy is running at any time.
So Poser 7 will work when you install it on your new computer - as long as your old computer doesn't RUN Poser 7 at the same time. But there's no need to uninstall Poser from your old machine.
2 problems I seriously need answers to.
I'm planning on getting a new computer soon. If I install Poser 7 on there, will it work?
~Hutton~
