Mon, Nov 11, 8:15 AM CST
Bryce F.A.Q (Last Updated: 2024 Nov 08 7:02 am)
Subject: Hi! I want to "Chop" out a portion of a circle...but I can't get the two to hili
FutureFantasyDesign ( ) posted Fri, 16 November 2007 at 5:31 PM · edited Mon, 11 November 2024 at 8:14 AM
Hi I guess I am not nearly as good as I want to be! LOL!
I have a problem cutting out a Boolean from another.
Here is where I am (*I have Bryce 6.1 open now) I have 2 spheres, 1 Negative and 1 Positive, they bisect each other as I intended for the cut process. I can get one to hilite, but when I hold down the CTRL key to hilite the other, it won't fly. What am I doing wrong and can someone give me "Cutting a Boolean" 101?
ThanX!
Ariana
Is there water in your future or is it being shipped away to be resold to you?
Water, the ultimate weapon...
www.futurefantasydesign.com
BecSchm ( ) posted Fri, 16 November 2007 at 5:35 PM
Hold down the shift key instead of the control key - on a PC, anyway.  Not sure about a Mac.  :)
FutureFantasyDesign ( ) posted Fri, 16 November 2007 at 5:37 PM · edited Fri, 16 November 2007 at 5:39 PM
OH! I have a PC....let me run and look! *woohoo!!!
UGH!!! darn darn darn darn!!!!
I hilite the one, and the other Un-Hilites! I need to hilite both right? I want to use the 2nd spher to chop out the 1st sphere. :(
Did I do something wrong or forget a step?
HuggerZ!
Ariana
BecSchm ( ) posted Fri, 16 November 2007 at 5:42 PM
Click on one sphere to select it.  Hold down the shift key to select the 2nd one.  Hit the little "G" to group them.  Hope I have explained it well enough.  :)
FutureFantasyDesign ( ) posted Fri, 16 November 2007 at 5:43 PM · edited Fri, 16 November 2007 at 5:48 PM
OK, I am off again! Thank you..I swear I am not stupid... :/
Me
*sigh I hilited the 1st sphere, held down the "shift" key and right click? I tried both and neither would allow the two to both hilite. I don't know where the little g is because it didn't materialize, or do I hit g on my key board while holding the shift key? I'm sorry...I do good groupings inside of poser! Try again?
Me
TheBryster ( ) posted Fri, 16 November 2007 at 5:44 PM
Forum Moderator
You could always click and drag around the two spheres.............
FutureFantasyDesign ( ) posted Fri, 16 November 2007 at 5:49 PM
Hi TheBryster, I am trying to cut out one sphere to make a crescent shape, does that help?
Ariana
FutureFantasyDesign ( ) posted Fri, 16 November 2007 at 5:51 PM
OH OH OH I DID IT!!!! I at least got both to hilite! Yippee!!!
I'll be back with info....I found the G!
Ariana
BecSchm ( ) posted Fri, 16 November 2007 at 5:54 PM
It's fun when it works, isn't it?
FutureFantasyDesign ( ) posted Fri, 16 November 2007 at 6:01 PM · edited Fri, 16 November 2007 at 6:02 PM
OH wait How do I get the smaller sphere to chop itself out of the bigger one????
I have the two grouped and red hilited....
Me
BecSchm ( ) posted Fri, 16 November 2007 at 6:06 PM
You did go into the properties of each sphere and make one positive and one negative?  You have to highlight the first one and click on the A and make it positive.  Same with the second one but make it negative.
FutureFantasyDesign ( ) posted Fri, 16 November 2007 at 6:07 PM · edited Fri, 16 November 2007 at 6:09 PM
Yes I did that...do I just render now? Or do I cut? I am still a little confused.
BecSchm ( ) posted Fri, 16 November 2007 at 6:10 PM
Can you do a screenshot?  Here's a sample of the spheres grouped.
BecSchm ( ) posted Fri, 16 November 2007 at 6:11 PM
...and here's how it looks rendered
FutureFantasyDesign ( ) posted Fri, 16 November 2007 at 6:11 PM
AH!!!! I DID IT!!!! LOL!!!!
ThanX ThanX ThanX!!!!!
HuggerZ!
Ariana
BecSchm ( ) posted Fri, 16 November 2007 at 6:13 PM
UR welcome :)
FutureFantasyDesign ( ) posted Fri, 16 November 2007 at 6:14 PM · edited Fri, 16 November 2007 at 6:22 PM
Hmmmm....still doesn't look like a crescent to me. Well I tried to use the ring to do the crescent and i guess i never realized all boolean shapes are hollow? Can they be made solid???
Ha! Did it! I'll post my results in a moment!
Ariana
Heztia ( ) posted Fri, 16 November 2007 at 6:19 PM
Hey hun I don't know if this will help but it's what I used when I learned to make piece invisible ect..... [http://www.daz3d.com/i.x/tutorial/tutorial/-/?id=807
](http://www.daz3d.com/i.x/tutorial/tutorial/-/?id=807)Hope it helps :0)
"KnowThyself And Be Ture, Let Karma Do The Rest"
Mystic Images Freebies
BecSchm ( ) posted Fri, 16 November 2007 at 6:22 PM
If you make the negative sphere a little bigger and flatter than the positive sphere, you can get sort of a crescent shape.
BecSchm ( ) posted Fri, 16 November 2007 at 6:33 PM
something like this maybe?
BecSchm ( ) posted Fri, 16 November 2007 at 6:34 PM
..rendered
FutureFantasyDesign ( ) posted Fri, 16 November 2007 at 6:45 PM
ThanX so much everyone! I got it and it cmae out ok...I want to load some more textures to finish it off! Here's a peek!
HuggerZ!
Ariana
TheBryster ( ) posted Fri, 16 November 2007 at 6:50 PM
Forum Moderator
All boolean shapes are NOT hollow. Bryce Native Prims when booleaned are solid. Prims are only hollow when they've been imported from other people like Spacebones.
Heztia ( ) posted Fri, 16 November 2007 at 6:55 PM
Yah! awesome glad you got it hun!
Ang25 ( ) posted Sat, 17 November 2007 at 1:25 PM
For future referrence another way to select things (and it is especially good to give each thing a meaningful name) is to click on the icon at the bottom of the screen and select it from the drop down list.
For instance if you had five spheres and named them posSphere and negSphere and ball etc
Then you can just go to the drop down select posSphere and hold the shift key and select negSphere. It can save time and agony , especially if other objects are blocking the object you want to select. Takes out the guess work.
I also like to take selected objects into solo mode to make tweaks and adjustments to them.
HTH :)
FutureFantasyDesign ( ) posted Sat, 17 November 2007 at 5:52 PM
ThanX Ang25! And ThanX to everyone else too! This is the first time I have cut up stuff in Bryce...not as cut and dried the first time around! :)
HuggerZ!
Ariana
