Bryce F.A.Q (Last Updated: 2024 Aug 28 6:28 pm)
OH! I have a PC....let me run and look! *woohoo!!!
UGH!!! darn darn darn darn!!!!
I hilite the one, and the other Un-Hilites! I need to hilite both right? I want to use the 2nd spher to chop out the 1st sphere. :(
Did I do something wrong or forget a step?
HuggerZ!
Ariana
Is there water in your future or is
it being shipped away to be resold to you?
Water, the ultimate
weapon...
www.futurefantasydesign.com
OK, I am off again! Thank you..I swear I am not stupid... :/
Me
*sigh I hilited the 1st sphere, held down the "shift" key and right click? I tried both and neither would allow the two to both hilite. I don't know where the little g is because it didn't materialize, or do I hit g on my key board while holding the shift key? I'm sorry...I do good groupings inside of poser! Try again?
Me
Water, the ultimate
weapon...
You could always click and drag around the two spheres.............
Hmmmm....still doesn't look like a crescent to me. Well I tried to use the ring to do the crescent and i guess i never realized all boolean shapes are hollow? Can they be made solid???
Ha! Did it! I'll post my results in a moment!
Ariana
Water, the ultimate
weapon...
Hey hun I don't know if this will help but it's what I used when I learned to make piece invisible ect..... [http://www.daz3d.com/i.x/tutorial/tutorial/-/?id=807
](http://www.daz3d.com/i.x/tutorial/tutorial/-/?id=807)Hope it helps :0)
"KnowThyself And Be Ture, Let Karma Do The Rest"
Mystic Images Freebies
All boolean shapes are NOT hollow. Bryce Native Prims when booleaned are solid. Prims are only hollow when they've been imported from other people like Spacebones.
Yah! awesome glad you got it hun!
For future referrence another way to select things (and it is especially good to give each thing a meaningful name) is to click on the icon at the bottom of the screen and select it from the drop down list.
For instance if you had five spheres and named them posSphere and negSphere and ball etc
Then you can just go to the drop down select posSphere and hold the shift key and select negSphere. It can save time and agony , especially if other objects are blocking the object you want to select. Takes out the guess work.
I also like to take selected objects into solo mode to make tweaks and adjustments to them.
HTH :)
Hi I guess I am not nearly as good as I want to be! LOL!
I have a problem cutting out a Boolean from another.
Here is where I am (*I have Bryce 6.1 open now) I have 2 spheres, 1 Negative and 1 Positive, they bisect each other as I intended for the cut process. I can get one to hilite, but when I hold down the CTRL key to hilite the other, it won't fly. What am I doing wrong and can someone give me "Cutting a Boolean" 101?
ThanX!
Ariana
Is there water in your future or is it being shipped away to be resold to you?
Water, the ultimate weapon...
