Wed, Nov 20, 4:56 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 20 4:32 am)
Subject: Question re: .vob file extension
Acadia ( ) posted Mon, 19 November 2007 at 8:29 PM · edited Thu, 15 August 2024 at 12:37 AM
I know the .vob extension is for Vue. I have the free Vue 6 Infinite PLE
I found a freebie that I would like to use and it has a .vob extension and I want to convert it to .obj so I can use it in Poser.
The readme for the file says:
[quote]To Install:
  • Move the .VOB file to one of the object folders under your Vue
    d'Esprit directory, and it will display in your object browser the next
    time you open Vue d'Esprit.[/quote]
Where in the Vue folder do I find the folder that has the objects in it?
in the top level of the Vue folder I have the following:  Application, Documentation, Environment, Help, Modules, and Python.  I've looked in each of those and don't see any "object" folders.
diolma ( ) posted Mon, 19 November 2007 at 8:50 PM
Hi Acadia.
Drop the .VOB anywhere - any folder anywhere.
Start V6I PLE. Go to File Menu->Load Object. You should get the "Top level" dialogue. At the bottom of that dialogue there's a browse option (next to the waste bin - hover over the icons there). Click the browse option and you should be able to browse to wherever you saved the .vob and load it.
However, I rather think that you won't be able to save it out as eg. a .obj file (tho I hope I'm wrong).  Many .VOB files are set up so that they cannot be re-exported.
However, just in case I'm wrong, to try to do so select the object, and go to File Menu->Export Object. Select .obj format.
Hope that works (I have V5I, not V6I, but I'd be surprised if these bits have been changed)
Cheers,
Diolma
Acadia ( ) posted Mon, 19 November 2007 at 8:59 PM
Thanks :)  I'll give that  a try tomorrow. Right now my bed and book are calling out to me.
jenay ( ) posted Tue, 20 November 2007 at 10:30 AM
let me know if you are successful .)
as far as I read the doku it's not possible to interchange files with the PLE of Vue. maybe I am wrong ...
SSAfam1 ( ) posted Tue, 20 November 2007 at 11:31 AM
Acadia what do you use Vue for? What are the pros?
svdl ( ) posted Tue, 20 November 2007 at 12:12 PM
Vue is a landscape generator and renderer.
Pros of Vue:
  • much faster raytraced renderer, better render quality possible;
  • liquids and metals render far better than in Poser;
  • great handling of plants, trees and rocks;
  • in the Infinite version: ecosystems ("crowds" of objects, with individual variations if the objects are plants or rocks)
  • in the Infinite version: full 64 bit (can render scenes wiith enormous complexity without a hitch).
  • easy import of Poser scenes, either animations or stills;
  • supports Poser dynamic hair and cloth;
  • and much, much more.
Cons of Vue:
  • precise placement of objects is harder to do than in Poser;
  • no polygon subdivision (except in Infinite, and that doesn't work as well as polygon smoothing in Poser)
  • displacement is still somewhat flaky and can be extremely RAM hungry.
My gallery   My freestuff
Acadia ( ) posted Tue, 20 November 2007 at 12:27 PM
Quote - Hi Acadia.
Cheers,
Diolma
I can't seem to load the .vob object file. I get some message saying that Vue 6 can't read files for Vue d'esprite or earlier and to use the conversion tool to convert the file.
Acadia ( ) posted Tue, 20 November 2007 at 12:29 PM
Quote - Acadia what do you use Vue for? What are the pros?
I have no idea!  LOL I saw someone talking about the free version of Vue so I decided to download it and try it out. Apparently renders are supposed to be much better or something. TBH I even though I installed it,  haven't bothered with it. I'm still trying to figure out Poser and with me it's one program at a time because I'm easily overwhelmed when I try to learn too many things at the same time.
SSAfam1 ( ) posted Tue, 20 November 2007 at 12:34 PM
Yeah I know StormChaser loves Vue for rendering but didn't know if the free version would come equipped with all the things needed.
FrankT ( ) posted Tue, 20 November 2007 at 1:20 PM · edited Tue, 20 November 2007 at 1:22 PM
Few more pros for Vue
Volumetrics - you can see 'em in the preview and they render much faster than Poser.
GI and GR without having to hack secret settings (and which work )
Placement of things that aren't in Ecosystems is actually as precise as Poser - you can adjust Z Y and Z independently if you need to.
Density maps for Ecosystem layout and ecosystem painting in Infinite, surprisingly useful
and yeah - almost all my renders are done in Vue these days - 900x1500 in 2 or 3 mins with volumetrics (but not with GI obviously)
My Freebies
Buy stuff on RedBubble
SSAfam1 ( ) posted Tue, 20 November 2007 at 1:34 PM
^Are these available in the FREE version as well?
FrankT ( ) posted Tue, 20 November 2007 at 1:37 PM
you'd have to check the website but so far as I know ecosystem painting is available in the PLE.  The rest of it certainly should be
My Freebies
nruddock ( ) posted Tue, 20 November 2007 at 1:55 PM
Quote - I can't seem to load the .vob object file.
As someone else mentioned, the PLE has a restriction that stops it from loading files from non-PLE versions.
