Philc, i guess i don't get it. Add full body morphs , does it mean it adds the v3 morphs of the orignal v3. meaning it wil copy v3 morphs at value 0? Then how is it the clothes will fit my own v3 modified character if my character had for example hip xscale to 111%? And also how does it know to add the morphs of a specific Analized figure, if the morphs that i select when i convert are called with generic names such as "Barbarian", etc... which gives no relation to my morphed v3 character
So i select convert from figure v3 and convert to figure v3 Yeah i always select add full body morphs. and then i get: which body morphs do you wish to transition? V3 Ankle Spandex.mor v3 armor glove v3 barbarian1 v3 barbarian2 v3 biceps v3 breast size 3 etc. I select none. But my question is i don't understand, how does this process use the Analyzed thing that i did when i analyzed my v3 character( character for v3 which i bought in renderosity )? I mean, i never got asked to locate that character or anything.
Ohhhh i got it. In the Poser Figure menu. That's write, i did it and now it really made a dial for my figure:) Great So now when i do the Analize thing, i get a pop up.. WHICH MORPHS DO YOU WANT TO ANALYZE, and i do get the MORPH i created . it's in there along with many others. so which do i choose? All of them or just that morph?
Any or all that you require.
Obviously do not select a morph that is not made for your figure, they will be clearly notated.
Do review the available "WW" morphs that we built in. Some like WW Looseness get built in automatically because they are so useful but there are a number of others available as options.
Stand alone
Ctrl+ click (Command+click) to multiple selce from the list.
Ok i chose just the Morph i created. Then i now try the CONVERT button, chose a dress, set my target directory and Select Convert from V3 CONVERT TO V3. is this right? press convert and then select non of the morphs that it offers in a pop up. Then i'm waiting.. So i stopped the converting cause im not sure of something. If i'm converting the clothes from v3 to v3. I just don't get it. the CONVERT TO doesn't specify my character. so what is it really converting to? This is not explained in the Help page, so i'm confused. but i'm gonna let the conversion and see what happens
"Select Convert from V3 CONVERT TO V3. is this right?"
Your initial task indicated that you wanted to get an item of clothing that was made for V3 to fit a morphed version of V3. So the answer to this question is ... Yes
"press convert and then select none of the morphs that it offers in a pop up."
Why select none? The very reason to be doing this is to place a morph in the clothing that matches the V3 morph. Select the custom V3 morph. Then as an option select some-all-none of the other available "WW" morphs as you require.
"I just don't get it. the CONVERT TO doesn't specify my character."
Your "To" character if I'm understanding you correctly is V3 with a custom morph in it. You will have ... or should have... selected the morph in the paragraph above. Wardrobe Wizard 2 has all the information it needs to perform the task.
Does that clarify?
I guess what is not happening is the Dress is not getting the Margot Body morph into it... so it's not going to fit her. So where in the process do i get the margot body morph that i made INTO it? That's why it doesn't have it cause the process , as i see it, doesn't do anything about getting the character's morph. Sure it gets the V3 one because that is in the CONVERT TO , but not my modified v3 body morph.
In the Analyze step i do select Margot morph.. But in the COnvert step...all there is to select are v3 morphs .....OH i got it...I'm just seeing it now and in the list my Margot morph is there:) Wow i didn't see it cause it's quite a long list of morphs and also it got renamed to V3 Margot..i named it just margot when i created it but so it's v3 margot. got it: ) Oh reason i didn't see it before. There are two pop ups windows.: 1st "Which clothing morpsh shall i keep?" 2nd "Which body morpsh do you wish to transfer?" The second question is where my morph is listed. The first few times when i trid it, i skipped or didn't see the second pop up window, so no wonder i didn't see my morph. Well now, i'm starting to get it:) Thanks i'll try to convert again hopefully the dress now will fit and not look like it looks in my pic
Does the original Margot figure actually contain the morph data or does it reference an external binary morph file? The help file indicates that the morph data should be within the CR2 file and not external.
If that is the case:-
In Poser go to Edit > General Preferences > Misc and ensure that "Use External binary morph targets" is not selected.
Now load your Margot figure
Select the BODY
Turn the Margot dial to ensure that it works
Save the figure to the library.
Clear the scene.
Load the saved figure and reanalyze it again. (The dial setting will not matter)
Is a WW Margot dial being created in the BODY of the clothing and if so have you set its value to 1.000 ?
Is it possible for you to send me that dress CR2 file and its accociated OBJ file? If not could you repeat the process using the P4 catsuit (convert to V3 first) and send me the resulting CR2 and OBJ. We both have the catsuit so you'll not be sending me something that I do not already have.
In that way I can better see what you see.
Thanks.
maybe if he's using mac on standalone it is not finding the thing to analyze (like my problem that i had) love esther
I aim to update it about once a month. Â Oh, and it's free!
A WW Margot Dial is not created. but a dial called V3 Sexymargot( Sexymargot is what i named it when i c reated the full body morph from file menu) was created.. but when i set it to 1 or to -1 nothing happens. Sure i'll do the P4 catsuit thing but i guess later cause i'm suffering with a tooth problem so i can't concentrate with poser now
Ok another thing i'm noticing. I converted Jersey Dress( from hongyu sold at renderosity) from V3 to V3 Margot, yesterday. i did it a couple of times, it's the one i posted first. But now if i try to convert it i will get that same message "Skipping anaylysis of hongyu Jersey.." and then when it's supposed to go to the next step it gets stuck on that message and nothing happens. Another thing i'd like to tell you is that i successfully converted( yesteerdaY), V3 Jersey dress to the BASE Miki. note, the base miki.. not any miki character which has been modified. . That looked awesome. But i'm sure if i do it the way i'mm doing it, it would fail in converting it to a modified Miki chahracter.
Yes I know. I've been trying to ask question to diagnose what you are doing but have not been able to from the answers received. May I crave your patience as I ask again.
Could you please let me know if you are using a PC or a Mac?
Are you permitted to send me the V3 figure in order that I may see exactly what you see and hence be better placed to accurately answer you.
Oh phil c, i made a discovery right now. I loaded my margot, then i created full body morph from file menu. And it did. Then i said what if i set the dial from 0 to -1.. The body, It should turn back to regular v3 base . And interestingly, IT DIDN"T!!!!!!!!!!!!!!!!!!!!!!! The only thing that turned back to v3 base was the face of the character. That's weird.. So i think i'm getting somewhere. Cause if the morph that i create is just the face... then of course the clothes is not going to change to the shape of Margot. Also, when i CREATE FULL BODY MORPH OF THE MARGOT, I select the figures Body. not the face. This is weird.. maybe a problem with poser? I have poser 6 sr 3 installed.
Yes you have provided me with ample explanation as to your perception of the problem but unfortunately insufficient detail to my specific diagnostic enquiries. Could you please let me know if you are using a PC or a Mac?
Also and possibly a more direct rout to the answer is it possible for you to send me the CR2 file of your Margot figure? In that way I'll be able to see exactly what you see first hand.
I again thank you for your patience.
I tried this just to see if full body morphs work, and it does't seem like it. Loaded a monkey figure. Scaled it's body in XScale and from that Created a full body morph. Then i set back the Xscale to 100 ( That is the regular default ) Then in the new morph i set it from 0 to 1 and it didn't change. The body didn't change, but the face did. when i set the dial to 1 the eyes would gradually shut. What the? I was expecting that the body would change, not the f ace.
I was reading the manual and it said you can only do full body morphs using the morph dials of each figure. like in v3 there's Breast morph, bicep morph. I tried doing this, set bicept to 1 set breast3 to 1 and it change those body parts. then i did the create fufll body morph. and that DID work. because when i rotate the new full bodymorph dial it changes those 2 body parts. But when i Create full body morph out of my v3 margot's figure, and then roate the dial, nothing happens to the body but the face does change between margot's face and v3 base's face.. So, i don't know..
The convert to list is just the same list as the other list. it's the same characters but those are the base figures, V3, miki, etc. But how about if you bought a v3 character which of course may have the body changed. or if you made your own v3 character by using morphs. Then , what should i select ?
