Sun, Feb 9, 3:28 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: A script for making a full body morph of other full body morphs.
bopperthijs ( ) posted Sat, 24 November 2007 at 4:04 PM · edited Sun, 09 February 2025 at 12:29 AM
Perhaps this sounds a little cryptic but a lot of custom characters ( bought or self-made) of V3,V4 and other DAZ3D figures are made by the setting of the Full Body moprhs of the characters.
If I want to make a FBM of those settings for storing for later use, only the face morphs are saved and not the body morphs in the FBM.
AFAIK (in my humble poserknowledge) the only way this can be solved is by setting the individuable bodypart -morphs to the same settings as the full body morph settings. ( or spawning them, but I don't think that's a good solution)
But if you have a lot of FBM dials set, this can be a very tedious task. ( if you done it once you never want to do it again)
I want to make some custom FBM  of my favourite home-made and bought characters to use them in the new wardrobe-wizzard.
I think it's possible to make a python-script to do the job, but I don't know python: is there someone who would give this a try?
Best regards,
Bopperthijs
PS. I think a ot of WW2-users will be very happy with this!
Angelouscuitry ( ) posted Sat, 24 November 2007 at 10:19 PM
SVDL's Spawncharacter.py?
bopperthijs ( ) posted Sun, 25 November 2007 at 5:30 AM
Well, Spawncharacter does allmost what I want, except that I have now new morphs in everybody part, and I just want the original bodymoprhs be set like  the full bodymorphs are, so that I don't have extra morphs, Tebop describes the proces by hand in the poserforum.
In my opinion this can be done easier, but I'm python witer, perhaps anyone can give his opinion on this.
best regards,
Bopperthijs
Angelouscuitry ( ) posted Sun, 25 November 2007 at 8:48 AM · edited Sun, 25 November 2007 at 8:57 AM
You might also consider using spawncharacter with Ockham's ZeroMorph.py and, and/ SVDL's remove morphs.  If you have your figure the way you want, and create the INJ, do'nt apply it yet.  First run ZeroMorphs.py, this will revert all morph dial values to zero.  Then run RemoveMorph.py, this will delete any morph dials with a value of zero(all.)  Now use the INJ from SpawnCharacter, and you should have a very lite version of you figure?
jancory ( ) posted Sun, 25 November 2007 at 9:19 AM
lost in the wilderness
Poser 13, Poser11,  Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine!  Win11, I7, RTX 3060 12GB
 My Freebies
bopperthijs ( ) posted Sun, 25 November 2007 at 12:18 PM
I'm afraid those scipts only work in poser 6, and I haven't installed that.
but thanks anyway,
best regards,
Bopperthijs
bopperthijs ( ) posted Sun, 25 November 2007 at 2:48 PM
I did some tests and spawncharacter works for me,  I can make a FBM-inj file, inject in a character and save that. That character can be used for analysing in WW2.
Okay  thanks, saves me a lot of time.
Best regards,
Bopperthijs
