Sat, Jan 25, 10:56 PM CST
Subject: problem with rendering image in P7
vxg139 ( ) posted Sat, 01 December 2007 at 10:46 PM · edited Sat, 25 January 2025 at 4:52 PM
Hi,
I seem to be having problem with one of my poser files. the image looks ok in "preview" mode, but when I render it, image ends up too "dark" + it flips (pls see image)...
Any advice as to how to fix this porblem would be greatly appreciated....
BTW, I am using Poser 7....
Thank you
vxg139
jentron ( ) posted Sat, 01 December 2007 at 11:25 PM
Two questions:
  1. Why are you using the Poser 4 render engine?  (That is the config screen for the Poser 4 renderer)
2,  What exactly are you rendering?  It looks to me like maybe a model of a picture frame?  Does it contain a glass material over the front that is reflecting/mirroring the picture as well as a black environment color?
Jentron
vxg139 ( ) posted Sat, 01 December 2007 at 11:33 PM · edited Sat, 01 December 2007 at 11:42 PM
Oh..
I mainly use Poser 4 rendering option (as opposed to firefly) since it is faster.....
on your 2nd question.... the picture frame does not include a reflecting surface.... the prop has two components.... the frame and the picture.....
not too sure what you mean by "environment" color.....
Cheers
vxg139
jentron ( ) posted Sun, 02 December 2007 at 12:04 AM
So what happens if you "ignore shader trees"?
And can you render from the back side of the picture?  I'm wondering if your normals are reversed, but I don't have time to expirement with that concept right now...
Good luck,
Jentron
vxg139 ( ) posted Sun, 02 December 2007 at 12:23 AM · edited Sun, 02 December 2007 at 12:31 AM
ignoring the shader tree didn't do it either..... just testing different settings, found a fix....added the image to "Ambient" (in Material room) and everything ok now!!
thanks for your help
Cheers
vxg139
