Sat, Jan 11, 6:33 AM CST
Subject: Lack of Basic Cut and Paste
Morphium ( ) posted Tue, 05 June 2001 at 10:19 PM ยท edited Thu, 08 August 2024 at 4:54 AM
For some ungodly reason, the cut and paste command in my Poser refuses to work. I can't copy specific body parts or props and paste them in other documents, or even in the same document. Is there some option that I need to turn on or off or am I simply doomed? Thanks.
PhilC ( ) posted Tue, 05 June 2001 at 10:36 PM
Poser's Copy and Paste feature lets you copy a shaped body part and paste the shaping Parameters onto another, or from one figure to another. It is not intended to copy objects to external programs. You have made a reasonable assumption, its just that the program is not designed that way.
Phantast ( ) posted Wed, 06 June 2001 at 4:54 AM
... which is a right royal pain. The best solution (at least for props) is: 1) select item 2) add to prop library 3) create a new instance 4) delete from prop library Haven't tried it with body parts. Probably won't work.
doozy ( ) posted Wed, 06 June 2001 at 5:06 PM
When you copy and paste, it's the dial settings that you are copying and pasting, not the meshes.
