Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 2:22 am)
I saw your post over at PhilC's. He gave some sample images on adjusting the falloff zone. I think he said it needs to shift over on the X (the right side more to the right, and the left side more to the left). But you say you've adjusted the falloff zones already and it's still wack?
http://www.philc.net/forum/viewtopic.php?t=1884&start=15
PhilC made alternative V4 joint parameter settings for you. Did you try that?
http://www.philc.net/temp/Alternative_V4_donor_CR2.zip
If you have tried all that, then I have a few questions for you:
Thanks. That will help me figure out if this is a grouping problem or JP problem.
bB
Thanks. That will help me figure out if this is a grouping, JP, or Magnet problem.
bB
Here we go, firstly I am getting these results on all clothing that has the crouch area.
I can see improvements all along, but still the major area seems to be the edges of the inside thigh crouch portion if you can by see the default pose position.
To answer your questions:
1.. From Aiko3 to V4
See new pic which has fall off zones corrected on thighs and is the newly converted cloth with the alternative V4 Cr2 used and the magnetised pose added,.
You can see from the picture that the movement is causing the edges to distort, the differences now seem to be just the edges. so the corrections have worked but I feel I may be missing something in the fall off zones.
I.e. the adjustments should be on the green circles only? or is adjusting the red circle areas worthwhile, and should these be on all movement areas or just bend and side bend ?
Thanks for you help Rowlando
Seek what you can never loose
Okay. Thanks for taking the time to post all of this. It does show the problem. I willl try an Aiko swinsuit type clothing to V4 conversion too and I will check the groups. Where did the swimsuit for Aiko come from that you used? Meanwhile, have you posted all this information on PhilC's forum too? PhilC and Kamilche are very, very good about fixing errors. The update for WW2 will be coming out soon, and if you found something, I'm sure they will fix it. bB
Soon, as in PhilC soon, and not Daz "soon." -^ I tried a conversion from batlab pant a3 to V4. I wasn't able to replicate the error. So my next question is: What did the original swimsuit look like on Aiko? Was there is any kind of alignment issues on the zeroed swimsuit (unconformed) compared to a zeroed A3 with no IK?
Hi bB
I get the same results on all cloths I convert including the V4 panties.
I converted the Philc lingerie Panties and get the same error in the edges of the crotch area as the prior pics show. would you post me your settings for the above batlab pant.
I have this too and would follow you settings you used in WW2.
I use the standalone version of WW2 so if you could use this and let me know your settings for the above results.
I have posted this stuff on WW2 forum and am waiting on some anwers, I think this will all work out fine, I love the program heeps.
Thanks again. Rowlando
Quote - If you were following the thread by Cage, you'll know that results of a conversion need cleanup in an external program. What I did with WW2 is the same, it's not perfect, but it at least gives me a starting point. If you are determined, you could get V4's morphs to V4V3,
What I would be interested in is getting V3s morphs into V4V3. (And S3s into A3S3, and D3s into H3D3).
I think a lot of people would welcome the idea of being able to transfer morphs to other figures.
But in all fairness the program has been designed to transfer morphs to clothing of other figures.
I think I saw a thread by Bepop where he was able to transfer morphs to other figures.
Thanks Rowlando
If you want V3's body morphs on V3V4, just use V3's body with V4's head. If you want V3's head morphs on V3V4, just use V3's head with V4's body. For S3 morphs in A3S3 just transfer the morphs in Morph Manger. Simple. (The same trick works for David morphs to Hiro, or S3 to D3, or V3 to S3, etc) If you want V3 and D3 (group 1) morphs on M3 and the Freak (group2), use Universal Morph Transfer here in the Rendeosity Marketplace. bB
For Mill 3 figures, use ShapeShifter at PhilC's, it's in the Freestuff stuff.
http://www.philc.net/freestuff.htm
For other figures, use the Ebonshire tutorial for Frankenstiening figures:
http://www.ebonshire.net/freebies/p-misc2.php
Those are the simple ways.
I'm also working on making my own versions of Aiko with V3 head, Hiro with M3 head, and V4 with V3 head.
bB
Oh. I thought I recognized, but wasn't sure. That hair looks GREAT on BJB too! ^^
WW2 is a lot of fun! BJD for some reason, maybe because of it's joints, poses really well. It's so cute, hard to resist! And now being able to put more clothes on BJD and BJB, I think maybe more people will be using them. ^^
Okay, New Tip for WW 2.15, the Update: If you have a clothing item you want to convert that's high polycount (like an Aery Soul garment) and you have less than 1 gig of memory, Do Not Batch Convert, and Do NOT Add Materials dials, at least not of the first conversion. Once you get the first one done, you can always go back and add more morph dials because the clothing has been already analyzed. Make sense? p.s. The sale on Wardrobe Wizard 2 ends Monday, Dec 17th. bB
Check this pic, I have adjust fall off zones but wow still goes crappy when posed in the crouch area, its happening on all V4 crouch area clothes.
Any suggestions using WW2 or other ideas.
Thanks Rowlando
