If you can switch to the 'Poser 4' renderer, text always looks best there,
with no fiddling needed. Of course if you're using ray-tracing or
fancy lighting, you can't make that change.....
My python page
My ShareCG freebies
I have created some label in photoshop to place on certain items. Lettering is included. However the lettering is readable only when you're zoomed in otherwise it appears as a blur. To partially correct I remove texture flitering. But still you'll get the letter H withough the crosshatch in the middle, etc.
Is there a certain font that works better on this? I can't seem to get good results with the lettering showing up satisfactorily.
By the way in preview mode - aside from the artifacting the lettering looks fine from any distance. It seems to be the firefly render. Suggestions?
Windows 10 - Poser Pro 2012 - 64Bit - 24GB RAM - 4 x 3.40 GHZ processor
