Thu, Jan 23, 8:09 PM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 23 7:54 pm)
Subject: Re-Install Daz
FranOnTheEdge ( ) posted Wed, 26 December 2007 at 11:17 AM · edited Thu, 23 January 2025 at 7:58 PM
Okay, I've got Daz Studio version: 1.4.16.0
I want to update to version: 1.8 or whatever it's called.
I've downloaded the prog or update... whatever...
My questions are I hope simple:
  1. do I double click on the downloaded daz...exe or is there some other way to install an update?
  2. how do I make sure I don't get billions of folders in the contents list?? as I only have a few there and would prefer to add just the occassional thing as I want to use it - otherwise I can't find anything with too many folders to search through.
Measure your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Fran's Freestuff
http://www.FranOnTheEdge.com
amirapsp ( ) posted Wed, 26 December 2007 at 12:46 PM · edited Wed, 26 December 2007 at 12:47 PM
Try this:
First uninstall 1.4. Then go to Control Panel/Add Remove Programs and remove Microsoft C+ Visual Studio. Also uninstall any plug-ins. Then install 1.8.
Hugs
Antoinette
FranOnTheEdge ( ) posted Wed, 26 December 2007 at 2:08 PM · edited Wed, 26 December 2007 at 2:12 PM
"Then go to Control Panel/Add Remove Programs and remove Microsoft C+ Visual Studio."
Ah.
I really don't think I want to do that.  Never having had to do it before on previous DS updates.  That's a fairly basic level program, isn't it, goodness knows what else uses that, which would then be trolluxed up.
Are you absolutely sure it's vital to do that?
I don't remember having to do that before...
Fran's Freestuff
amirapsp ( ) posted Wed, 26 December 2007 at 2:16 PM
I did it with my install of 1.8. Otherwise just back up your plugins. Delete them and install 1.8.
1.8 have their own plugins.
Hugs
AnnieD ( ) posted Wed, 26 December 2007 at 3:10 PM
Fran I just installed 1.8 and followed the instructions as it installed.
If you need to clean up extra folders after I guess you can go in and do that..I didn't have to.
And C+ will be installed by the program if you don't have the updated version..
“For those who believe, no proof is necessary. For those who don't believe, no proof is possible.”
[Stuart Chase]
RHaseltine ( ) posted Wed, 26 December 2007 at 5:10 PM
Just install, allowing it to add the MSVC runtimes and to uninstall the old version (which you should not have running at the time). When you are asked if you want to kep the previous search results, say Yes and your content folders will be as they were.
FranOnTheEdge ( ) posted Wed, 02 January 2008 at 12:38 PM
Okay, got it done now.  Not sure about what Plug-ins I had...
Too late now though.
Fran's Freestuff
AnnieD ( ) posted Wed, 02 January 2008 at 1:09 PM
fran, after I installed the new version, I found my plugins under  "view"   "tabs"....after someone told me where they were...lol    drove me crazy trying to find them.
[Stuart Chase]
FranOnTheEdge ( ) posted Wed, 02 January 2008 at 2:00 PM
AnnieD,
I'll look there... if I can first find the normal movement controls which seem to be missing in D/S 1.8.
Help? Anyone?
How do I navigate, move primatives (or anything else) in this so very different and confusing looking DazStudio?
Fran's Freestuff
AnnieD ( ) posted Wed, 02 January 2008 at 2:08 PM
Fran..the first thing I did was go in and set my work area back to the classic one.. (kinda like you can do with XP to use the old win 98 layout)
anyway..that put my tools right where I  knew they should be.  ;)
Other than that..you can find your tools  and dock them where you want them..they are under the main menu..you just need to put them wherever you want.
[Stuart Chase]
FranOnTheEdge ( ) posted Wed, 02 January 2008 at 2:18 PM
Arrrghhhh!  Which one of these totally strange new menus is the MAIN one?
And how do you get it to look like it used to (i.e. classic)????
When it was installing I let it go with "basic" which I hoped was normal - but it isn't - nothing looks normal at all.
I'm not saying I don't like the look of the layout but if I can't find the things I need to navigate normally, then I'm not going to be able to use it, so....
Please help? (small plaintive voice)
Fran's Freestuff
AnnieD ( ) posted Wed, 02 January 2008 at 10:06 PM
Here is how I did it.
Go to 'view' and then go to 'interface layout'  go to 'select layout' and on the right side of the pop up window..at the top ...will be a little pull down menu and in there are the styles you can pick from...including basic and classic.
You can go to each one and it shows you what it basically looks like and you can also edit whichever one you choose by moving the toolbars around or hiding them..etc.
All of it is done from the view menu...just take the time to look thru it all.
After you have chosen a work area and fixed it like you want it...be sure to save it so it will be there for you when you go back....
[Stuart Chase]
FranOnTheEdge ( ) posted Sat, 05 January 2008 at 6:49 PM
Okay, now my PC's hard drive has melted, so now I'm back to working on the laptop, which has the old version of D/S.
so I have a new question...
Can I install version 8 and still keep the older version workable?
Fran's Freestuff
amirapsp ( ) posted Sun, 06 January 2008 at 4:59 AM
No the old version will be overited. Sorry. Hugs
FranOnTheEdge ( ) posted Mon, 07 January 2008 at 7:21 PM
Pity.
Fran's Freestuff
Trevor666 ( ) posted Wed, 09 January 2008 at 7:25 AM · edited Wed, 09 January 2008 at 7:26 AM
I upgraded to D|S 1.7, found it wasn't compatible with WIN98SE, so I had to downgrade all the way back to 1.4.16 without all the current updates. In the meantime I did find the installation was quite easy, no problems, and it is possible to make the interface look identical to the 'classic' version then save the setup ( I sometimes get 'mouse happy' and screw up the settings!). And you can delete all the other interfaces from their folder, if you look for it.
spirittina ( ) posted Fri, 11 January 2008 at 7:07 PM
when i upgraded i just intalled 1.8 over1.7 and it workded fine but the 1.8 has some little errors that i dont like so i went back to 1.7
FranOnTheEdge ( ) posted Fri, 11 January 2008 at 7:17 PM
I couldn't quickly find 1.8 when installing everything to the new Hard drive in the PC so I put the one I did find on it, which turned out to be good ole 1.4.16 - it's working fine, no probs, so as it ain't broke I don't think I'll bother to 'fix it'.
Might upgrade later on.
Fran's Freestuff
