Mon, Feb 10, 5:16 PM CST
Subject: here it goes again....old thread: why my renders look dirty?
softcris ( ) posted Sat, 29 December 2007 at 8:17 PM · edited Sun, 09 February 2025 at 6:59 PM
well I came a bit late here/ there in the tread. but lately I'm experiencing some problems with right configuration for my computer's VGA and Poser. Final FireFly in the choice window,  high demanding lights,ultra high resolution ** **textures skins - still I got those dirty spots in the shadows area...
Now you guys sharper than I tell me one thing. My Poser is configure with the 'hardware shading' ..what is that?
"'you shut up!  or I'll bring democracy to your country! "
Cris Galvão aka Softcris  - www.crisgalvao.com
(or softcris, SoftCris)
Rendering since 1997 and
at Renderosity since 1999.
OS Win 8.1     64 bit
FrankT ( ) posted Sat, 29 December 2007 at 8:21 PM
an image is worth a thousand words.  How do you mean "dirty spots" ?
Hardware shading will only make any difference if your graphics card supports it I guess.  Mine has it set too for the preview but I don't think my card can use it
My Freebies
Buy stuff on RedBubble
softcris ( ) posted Sat, 29 December 2007 at 8:25 PM · edited Sat, 29 December 2007 at 8:37 PM
Quote - an image is worth a thousand words.  How do you mean "dirty spots" ?
well I guess my do. Look over here; ati X1600pro 512mb. Have never looked up on that but that vga is apretty good one..I render a 300MB pz3 file in FFF in about 3 min time...all heavy lights,shadows etc..
but I'm here pal ready to learn..so...if you can tell me where do I disable that I will do ND TRY TO RENDER SAME IMAGE and compare.
here is the PREVIEW image.
http://www.renderosity.com/mod/gallery/index.php?image_id=1587812
 I'm rendering one with the dirty shadow in it..give me some time...
OS Win 8.1     64 bit
FrankT ( ) posted Sat, 29 December 2007 at 8:31 PM
FireFly doesn't use hardware shading on the render.  The preview will though so you can't turn it off for Firefly because it's not on (if that makes sense)
My Freebies
FrankT ( ) posted Sat, 29 December 2007 at 8:36 PM
My Freebies
softcris ( ) posted Sat, 29 December 2007 at 8:47 PM · edited Sat, 29 December 2007 at 8:49 PM
well here is for to see the Final FireFly render using the window choice where is the 'automatc' as 'draft' and as 'final' so  I choose Final to render that image....still can't upload it!!
result is that..you can see the dirty shadows in close to the month and up in the hair - temples
.....for some strange reason I can't upload here the image..anyone knows why? it'skb  240 max
OS Win 8.1     64 bit
SamTherapy ( ) posted Sat, 29 December 2007 at 8:48 PM
The dirty spots may be due to any or all of the following, depending on your setup:
For Raytraced shadows, the Bias setting may be incorrect.  Too big a rate, you'll get horrible grainy edges.  Too low and you get render artefacts as the polys shadow themselves.  A setting of 0.25 to 0.28 is about as good as it gets for most things.
For Depth Mapped shadows, you should ensure you have a shadow map of at least 1024, else you'll get torn edges on the shadows.
You may also have bump or displacement maps set at too high values.  These can give all kinds of horrible black marks and distortions on an object's surface.
Also, remember that in real life, shadows are seldom 100% density.  You should experiment with values of 40%-80% for the greatest realism.
softcris ( ) posted Sat, 29 December 2007 at 8:51 PM
well that is the right answer...thanks
I'll set as you say and be back here to tell. THANKS A BIG :::
OS Win 8.1     64 bit
Sivana ( ) posted Sat, 29 December 2007 at 9:32 PM
Quick solution? Use realskin shadder by faceoff. Makes wonder (really!)
Since I use this script, I haven´t this dirty probleme anymore.
softcris ( ) posted Sat, 29 December 2007 at 9:42 PM · edited Sat, 29 December 2007 at 9:43 PM
ok here it goes: I'm at Manual settings in Poser 7 sr2.
  • Min  shading rate ( I understod it means your For Raytraced shadows, the Bias setting may be incorrect.) so I corrct it to 0,26.
  • for: Depth Mapped shadows, I can't find where is it. But if is it in Preview Mode I have it at 2048 mb.
  • may also have bump or displacement maps set at too high values. Mine were at 0.000 !! Trust!
  • is that related to the amount /strengh of each light shadow? values of 40%-80% for the greatest realism. Please could you explain that a bit clearer? thanks.
OS Win 8.1     64 bit
softcris ( ) posted Sat, 29 December 2007 at 9:52 PM
ok where to get that?realskin shadder by faceoff.
OS Win 8.1     64 bit
Sivana ( ) posted Sat, 29 December 2007 at 10:24 PM
Vor V4 at DAZ for other figures here on marketplace. It really helps much to make a texture real.
