Fri, Jan 3, 6:49 PM CST
Subject: Any fighter pilot helmet for V4?
saus69 ( ) posted Mon, 07 January 2008 at 7:33 PM · edited Fri, 03 January 2025 at 6:48 PM
I can't find any in the freestuff section. Was wondering if there are any modern/post-vietnam figher plane helmets for the v4 model.
mrsparky ( ) posted Mon, 07 January 2008 at 9:05 PM
Attached Link: http://www.vanishingpoint.biz/productdetail.asp?productID=115
Not free and not originally for V4 - but try the link above.
Just use the parameter dials to make it fit and then parent to the head.
Theres also another model on sale here - but I can't seem to find it.
mhscspo ( ) posted Mon, 07 January 2008 at 9:20 PM
Attached Link: http://rapidshare.com/files/82115526/flighthelmet.zip
> Quote - I can't find any in the freestuff section. Was wondering if there are any modern/post-vietnam figher plane helmets for the v4 model.
Try this and see if it works..
saus69 ( ) posted Tue, 08 January 2008 at 4:37 AM
Can't use rapidshare... is it hosted anywhere else?
mhscspo ( ) posted Tue, 08 January 2008 at 10:10 AM
Quote - > Quote - Can't use rapidshare... is it hosted anywhere else?
Try this one:
http://megaupload.com/?d=RLU281BT
pakled ( ) posted Tue, 08 January 2008 at 8:28 PM
not exactly fighter helmets, but there's some Sci-Fi helmets for the earlier Vickies at Runtime DNA (I think they're Maveris' helmets, but they could do in a pinch). In the freestuff...a ways back though...
DarkStarBurning ( ) posted Wed, 09 January 2008 at 4:17 AM
saus69 ( ) posted Thu, 10 January 2008 at 5:03 AM
Sorry, really cannot access megaupload. Can someone mail me that file at sausage at gmail.com? Thanks.
mhscspo ( ) posted Thu, 10 January 2008 at 7:58 AM
Quote - Sorry, really cannot access megaupload. Can someone mail me that file at sausage at gmail.com? Thanks.
Ok
saus69 ( ) posted Sun, 13 January 2008 at 7:25 PM
Just tried adding a custom diffuse texture to the helmet but I can't get it to work. I drew on the unwrapped map but when I use the material room to add this jpg as a diffuse texture, it comes out smaller than the helmet model.
What am I doing wrong?
mhscspo ( ) posted Sun, 13 January 2008 at 9:59 PM
Quote - Just tried adding a custom diffuse texture to the helmet but I can't get it to work. I drew on the unwrapped map but when I use the material room to add this jpg as a diffuse texture, it comes out smaller than the helmet model.
Make sure that your copy .jpg is the exact same size as the original
saus69 ( ) posted Sun, 13 January 2008 at 10:11 PM
It is... I was actually using the supplied template. Is there any way to stretch the map from within poser?
mhscspo ( ) posted Sun, 13 January 2008 at 10:31 PM
Quote - It is... I was actually using the supplied template. Is there any way to stretch the map from within poser?
I normally do everything in photo shop and then place things by way of the material room.
