Sat, Jan 11, 3:29 PM CST
Subject: V4 packaging questions... again
ninhalo5 ( ) posted Sat, 05 January 2008 at 5:06 PM · edited Thu, 02 January 2025 at 11:16 AM
Hi all, I know here we go again not another question on how to properly package.....
I hate to do this but my questions have never been resolved.
I have created a character for V4 LE  meaning no dials and no daz morph packs.
I would like to give my character to the community but I can not figure out the legal way to distribute her.
I have emailed Daz 3 months ago and no answer there. you would think with copywriting their material they would be happy to respond. guess I was wrong.
several people have told me to get this program and that program but these so called programs did nothing.  I forget what programs they were but they did something along the lines of setting up inj/rem files.... which would be ok if I used dials to create my character.
My character is made up of added morphs based on the original daz geometries (head, neck, shoulders ect..) so giving away the obj files is a no no, or is that the only way I can distribute the files but run them through our old friend objaction mover?
sending out just a pose file wouldn't be much of a help with out the obj files so I'm confused on what to do here. each morph to create the character is in an individual morph assigned to a body part.
Can anyone offer me a solution to this mystery?
thanks
patorak ( ) posted Sat, 05 January 2008 at 5:56 PM
Hi Ninhalo5
I did a custom full body morph for V3 in Lightwave,  exported the obj.  Then I fired up Poser's Little Helper and made an INJ/REM file for it.  No DAZ dials were involved,  just Lightwave,  Poser's Little Helper,  Poser 6  and a lot of help from the folks here.
Here's the thread http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2725718
Cheers
Pat
ninhalo5 ( ) posted Sat, 05 January 2008 at 6:14 PM
Thanks Pat, PLH was one of the programs that I tried though It only created a blank file. I also tried injection magic and that just looked at me like I was stupid....  it may be right  lol
I even tried Thorne's suggestion over at his site and that totally baffled me.
when it come to these scripts I have some sort of mental block...  I look at the structure of the file and my brain bleeds. :o)
svdl ( ) posted Sat, 05 January 2008 at 6:25 PM
You can use my MorphFromObjP6 script www.svdlinden.nl/webposerstuff/downloads/MorphFromObjP6.zip
It'll create an INJ/REM pose set for you. The deltas are within the INJ pose, and they are completely meaningless without V4LE (or V4, the morph will also work on the fully loaded V4).
The INJ and REM pose are safe to distribute, since there is absolutely no way to extract the V4 geometry from those files. The INJ file only contains the difference between the original vertex locations and the morphed vertex locations, without a clue as to where the original vertex used to be.
For the MorphFromObj script to work, you need the morphed V4LE as a single .OBJ file, with groups in the .OBJ that match the body part internal names of V4LE. If you haven't morphed the hands, you could export the morphed V4LE without hands (and MorphFromOBJ will not create a morph in the hands).
I don't know whether V4LE has injection channels. MorphFromOBJ requires injection channels to be present.
Hope this helps.
My gallery   My freestuff
ninhalo5 ( ) posted Sun, 06 January 2008 at 5:15 AM
thank you svdl your script has brought me closer than anything. however I must be setting up something wrong when creating my characters obj file. the end result turns her into the prey mantis woman. it looks as if her hands and feet are locked in place and her body is dropped a few feet. is there a special way to export her obj, certian check boxes I need to pick? and also I have 50 channels to choose from does it matter which channel I pick? thanks
svdl ( ) posted Sun, 06 January 2008 at 8:55 AM
Hmm.
What we see here is the result of messing up vertex orders. Some 3D modeling packages do that (3DS Max is notorious in this regard).
As for the channels, it doesn't really matter which one you pick.
Seliah ( ) posted Sat, 12 January 2008 at 3:24 PM
Quote - You can use my MorphFromObjP6 script www.svdlinden.nl/webposerstuff/downloads/MorphFromObjP6.zip
Question - using this with V4.1 ? Do I need to save the entire character out as a .obj file to do this? I've never worked with scripts before, period, ever, in Poser, so I have zero clue here what's needed.
~ Seliah
ninhalo5 ( ) posted Sat, 12 January 2008 at 4:51 PM
I'm trying this with v4 and I still have'nt got it right my characters get all blown up.
Mariamus ( ) posted Tue, 19 February 2008 at 6:14 AM
as far as I can see, it's because the morph is being imported with the hip hitting the floor.
Mariamus ( ) posted Tue, 19 February 2008 at 6:45 AM
I got the script to work just now. You have to zero the morphed figure, export it and then run the script.
Strange thing is that it doesn't bring in the upper and lower jaw morphs i made with it!
