Fri, Nov 22, 7:10 AM CST
Subject: Bryce convert it to OBJ?
Scorpiusb ( ) posted Wed, 16 January 2008 at 8:24 PM · edited Fri, 26 July 2024 at 5:01 AM
Attached Link: http://www.story.com
I have a question of the 3D gods here. I bought a Cityscape from here that is in Bryce format and would like to convert it to OBJ. However, I learned there is some other conversion that is needed before I can do that conversion, but I have no idea how to do it. Can you help?
Scorpius—
Story.com
TheBryster ( ) posted Wed, 16 January 2008 at 8:33 PM
Forum Moderator
You first need to have Bryce 6.1
If you have, the object (Cityscape) needs to be a booleaned object. That is, make it a POSITIVE object, add a NEGATIVE object (This can be anything you like and hidden in the Cityscape object) Boolean and then select/click the [C] icon.
You can then EXPORT object to a number of formats, OBJ being one them.
Scorpiusb ( ) posted Wed, 16 January 2008 at 10:28 PM
What I have is Alien City Blocks 2.  I'm not sure if it's boolen or not.  I just know it will not convert.  And I am new to Bryce.
Claymor ( ) posted Wed, 16 January 2008 at 11:54 PM
It isn't boolean
If you have the proper version of Bryce...
First thing I would do is to make the cityscape positive.
Select the object then click the little A and choose positive
Next create a sphere..any primitive really...and hover it over your city scape
Select the sphere, click A and choose negative
Now, select both the sphere AND the cityscape and click G to goup them.
You should have the G change to a U (ungroup) and a letter C (cut) should also appear
Click the C
go to FILE and the Export Object option should now be available!
That's the long version of what Bryster explained up there....
Scorpiusb ( ) posted Thu, 17 January 2008 at 1:26 AM
Okay, thanks guys.  I'll give it a try.
Scorpius--
electroglyph ( ) posted Thu, 17 January 2008 at 7:05 AM
Go to the help bar on te top of the bryce screen and click help topics to go to the online manual. Type the word attributes and click on the word attributes to see this picture of the menu box and explanation of how to set objects positive, negative, etc. Next type the word convert and follow the instructions.
Claymor ( ) posted Thu, 17 January 2008 at 9:17 AM
Dude!?!?! There's a manual???!!!
Sheesh...been using it since Bryce 2 and never seen the manual....
ellocolobo ( ) posted Fri, 18 January 2008 at 12:25 AM
It seems to work except on Bryce objects..
pakled ( ) posted Fri, 18 January 2008 at 1:39 PM
I have a Bryce manual, buried in a storage shed...somewhere..;) I thought there was a pdf in the last (free) Bryce version. Wouldn't cover the 6.1 stuff, but would be instructive (for that matter, check you Bryce directory for any pdf files. Might have been there all the time..;)
TheBryster ( ) posted Fri, 18 January 2008 at 1:41 PM
Forum Moderator
I have a Bryce manual, but I can't use it. It's propping up the table my pc sits on.....
Death_at_Midnight ( ) posted Fri, 18 January 2008 at 5:56 PM
Bryce came with manuals?
electroglyph ( ) posted Sat, 19 January 2008 at 3:35 AM
Bryce 5.5 came with a manual. Look in C:Program FilesDAZBryce 5.5Help
electroglyph ( ) posted Sat, 19 January 2008 at 3:36 AM · edited Sat, 19 January 2008 at 3:38 AM
Bryce 6 comes with a manual. Look in C:Program FilesDAZBryce 6DocsBryce6ArtistGuide.htm
electroglyph ( ) posted Sat, 19 January 2008 at 3:55 AM · edited Sat, 19 January 2008 at 3:55 AM
Of course there is always "The Preferred Method" of using Bryce.
Poke it with a Stick until something happens!
Thelby ( ) posted Sat, 19 January 2008 at 4:07 AM
Question about this guys: Do the Mats come out on the obj that is exported intact???
I would rather be Politically Incorrect,
Then have Politically Correct-Incorrectness!!!
Scorpiusb ( ) posted Sat, 19 January 2008 at 5:05 PM
Attached Link: http://www.story.con
This is why I love you guys.  This info is great.  Thanks :) Scorpius--
Thelby ( ) posted Sat, 19 January 2008 at 10:43 PM
Link doesn't work for me Scorpi. Perhaps we need Creighton to open it, he's the only one!!!
Scorpiusb ( ) posted Sun, 20 January 2008 at 11:43 AM
Sorry, the link is story.com.  I have some old 3D work there. Scorpius--
evielouise ( ) posted Fri, 25 January 2008 at 10:02 AM
Good  day from LA :
I was cracking up at some of  these comments
I just wanted to say you sent a smile to my otherwise tired morning  face LOL
Have a great and creative day:: ttfn hugs from the desert :
