You first need to have Bryce 6.1
If you have, the object (Cityscape) needs to be a booleaned object. That is, make it a POSITIVE object, add a NEGATIVE object (This can be anything you like and hidden in the Cityscape object) Boolean and then select/click the [C] icon.
You can then EXPORT object to a number of formats, OBJ being one them.
It isn't boolean
If you have the proper version of Bryce...
First thing I would do is to make the cityscape positive.
Select the object then click the little A and choose positive
Next create a sphere..any primitive really...and hover it over your city scape
Select the sphere, click A and choose negative
Now, select both the sphere AND the cityscape and click G to goup them.
You should have the G change to a U (ungroup) and a letter C (cut) should also appear
Click the C
go to FILE and the Export Object option should now be available!
That's the long version of what Bryster explained up there....
I have a Bryce manual, buried in a storage shed...somewhere..;) I thought there was a pdf in the last (free) Bryce version. Wouldn't cover the 6.1 stuff, but would be instructive (for that matter, check you Bryce directory for any pdf files. Might have been there all the time..;)
I have a Bryce manual, but I can't use it. It's propping up the table my pc sits on.....
Attached Link: http://www.story.con
This is why I love you guys. This info is great. Thanks :) Scorpius--Attached Link: http://www.story.com
Sorry, the link is story.com. I have some old 3D work there. Scorpius--This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
I have a question of the 3D gods here. I bought a Cityscape from here that is in Bryce format and would like to convert it to OBJ. However, I learned there is some other conversion that is needed before I can do that conversion, but I have no idea how to do it. Can you help?Scorpius—
Story.com
