Carrara F.A.Q (Last Updated: 2025 Feb 13 6:48 pm)
I click in the time line...
...anticlamatic, eh?
Nothing happens...
If it any consolation, I had the fan oscillating and spinning in a looped animation yesterday. But, I still don't understand the selection for the tweeners, whatever, they're trying to get me to understand.
It must be nice to still have a pliable brain!
Yank My Doodle, It's a
Dandy!
Reset your preferences to get all the colors back to default. Then you'll see.
Hi CJ, When this "clicks" you'll kick yourself - like all things in 3D. ;) It sounds like you are new to animation. Dragging a key frame isn't enough, you'll actually need to create a new one so that you have two on the same line. The space between the two key frames (the little black triangles) is the tweener. How do you make a new key frame? Simply move the time marker further down the timeline and then change the item in the scene and Carrara will create a new key frame automatically. I don't know what the tutorial is asking you to move or change but by completing the request with the timeline indicator further along in time, a key frame will be made and then you'll have a tweener also.
Attached Link: http://www.safehaven-uk.org/cryptojoe/Resource Reclamation.zip
Okay, I must have missed something in the tutorial about moving the object...Yes, I'm familiar with the terms of Timeline and Keyframe; its the Tweeners I'm new to. Im sure they exist, but they were seemlessly invisible in Rhinoceros 3's Bongo Animation program.
Again, the link to my video is above. It will download a 82 Meg zip file
Dandy!
Tweeners are short for what happens in the space "between" two keyframes. Before computers it was up to the artist to figure out the in-between motion and appearance, position, etc. for all the objects for the frames in between keyframes. This was back in the day when all animating was done by hand, not that long ago actually. As Mark said, you must create another keyframe further down the timeline for Carrara to know that it needs to "tween" any property. Say for instance you move the object on frame 60, Carrara will do the work of calculating all the intermediate frames in between. That way, if you scrub the timeline to frame 35, the objects' position will be calculated and the object will be drawn where it should be for that frame. The tweener is just the end users ability to decide how Carrara will make that transition between keyframes.
I'm using Carrara 6 Pro, and the hand book is for Carrara 5.Okay, we are in the Assembly room, the tutorial is saying:
"...click once between the first key frame and the last key frame on the time line for the fan group; notice it turns yellow. (Nothing turned yellow mind you) In the Properties Tray, Carrara displays the properties for the Tweeners..."
Don't see that ether. What I see is posted above.
Is it me, or do I need to buy the same hallucinogens the author is using?
Yank My Doodle, It's a Dandy!
