Sun, Feb 9, 6:34 PM CST
Subject: Diabolic Hybrid?
jcrous ( ) posted Mon, 28 January 2008 at 11:31 AM · edited Tue, 04 February 2025 at 5:00 PM
Hi,
I am currently using mostly A3 and V4 as my females and M3 as my male characters.
You can not buy everything you see and want, so you have to compromise.
I want to know if I can hybridise a head of a V4 figure onto a A3 body and save it as a new character morph.
I have seen something about this topic in tutorial format somewhere, but I have not taken notice and now I can not find it. I am not even sure if it is what I think it was?
Regards
Johan
Regards
Johan
nyguy ( ) posted Mon, 28 January 2008 at 11:55 AM · edited Mon, 28 January 2008 at 11:55 AM
in issue 99 of 3d world magizine they have a great tutorial on what you are trying to do. Try searching their site.
Poserverse The New Home for NYGUY's Freebies
Kalypso ( ) posted Mon, 28 January 2008 at 2:58 PM
Site Admin
Crescent has a couple of tutorials on "frankensteining" figures here:
http://www.ebonshire.net/tut-posa/index.php
I think they may require you to model a neck but I skip that part and use the neck from the figure whose body I'm using since I am not doing animations and can postwork any problem areas.
Hope this helps.
bopperthijs ( ) posted Mon, 28 January 2008 at 7:16 PM
If money is an issue you should download Appolo maximus as a male character, it's free model with several free textures and one of the best poser-models being around these days!
Here's the link:
www.antonkisieldesigns.com/~akfiles/htmlpages/ApolloMaximusFree3dhumanfigure.htm
regards,
Bopperthijs
ThrommArcadia ( ) posted Tue, 29 January 2008 at 3:01 AM
If outfits is the concern (as it often is) what you might want to do is get a plugin or software for converting clothing from one character to another.
Here are some of the popular options:
Wardrobe Wizard
CrossDresser
Clothes Converter
Each has it's loyal following and I have not used all three so I could not tell you the main differences.  I will say that the power to make you A3 outfit fit on V4 might change your world.
Hope this helps.  If I completely misinterpreted your needs, then ignore me.
estherau ( ) posted Tue, 29 January 2008 at 4:18 AM
sometimes what's needed is the poses not the clothes, so converting clothing doesn't solve everything. frankensteiing is also good. Love esther
MY ONLINE COMIC IS NOW LIVE
rofocale ( ) posted Tue, 29 January 2008 at 6:17 PM · edited Tue, 29 January 2008 at 6:21 PM
Attached Link: http://www.ebonshire.net/tut-posa/poptop-a1.php
...or you can follow this great and simple tutorial! The only thing is that V4´s head and neck differ a bit from the other ones, but postwork or a touch of magnets (or both) will do the thing :)) Trust me...it works, almost every character in my renderings are hybrids! Check out my gallery and see for yourself.
estherau ( ) posted Wed, 30 January 2008 at 6:12 AM
I once tried that tutorial to put V4 head on /v3, but unfortunately after getting halfway, the instructions weren't good enough for me because V4 has extra parts in her mouth and tonuge so I couldn't hack the Cr2.  hacking up a fur ball would have been easier.
Love esther
PS good tut for transplanting heads from one mil figure to another though.
Kalypso ( ) posted Wed, 30 January 2008 at 8:21 AM
Site Admin
Well if you're swapping between unimesh figures you can always just use Kamilche's script Shapeshifter found at PhilC's site.
http://www.philc.net/freestuff.htm
rofocale ( ) posted Wed, 30 January 2008 at 11:25 AM · edited Wed, 30 January 2008 at 11:26 AM
...strange, I had no problem with that. I just did as I had done with the Mill 3 and 2 hybrids.
Just followed the tut!
estherau ( ) posted Wed, 30 January 2008 at 5:23 PM
I should look at that tut again then, but I already tried it twice before. Love esther
rofocale ( ) posted Thu, 31 January 2008 at 1:57 AM
estherau
Export the tounge and teeth by following the same procedure as for the head and eyes(V4).
estherau ( ) posted Thu, 31 January 2008 at 8:34 AM
I did export them, but I was stuck when it came to incoorporating the code into the Cr2 Love esther
rofocale ( ) posted Thu, 31 January 2008 at 9:47 AM
Better luck this time :)
