Thu, Feb 13, 10:40 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Feb 12 7:20 pm)
Carrara Free Stuff here.
Subject: Confused? Transposer or not?
wscottart ( ) posted Thu, 14 February 2008 at 7:31 PM · edited Mon, 10 February 2025 at 1:59 AM
I really cant keep up with all the changes all the time , seems like I get a new version of carrara every time I turn around. At any rate do I still need transposer with carrara pro 6?
GKDantas ( ) posted Thu, 14 February 2008 at 7:39 PM
Yes and no! Transposer in C6 only used IF you have scenes created in C5 using transposer. Other way you will build your scenes using the Runtime in the browser.
Follow me at euQfiz Digital
wscottart ( ) posted Thu, 14 February 2008 at 7:47 PM
Wow, this programs really growing complex. So if i want to use content from runtimes scattered all around my computer, it would be best to load up transposer, or try to drive myself insane and copy all my runtimes into one place?
almost makes me fear going from poser 5 atm to poser 7.
GKDantas ( ) posted Thu, 14 February 2008 at 8:00 PM
You can add all your Runtimes to the Browser. Dont need t use Transposer anymore.
wscottart ( ) posted Thu, 14 February 2008 at 8:22 PM
ooo much easier to figure out once i slowed down and looked at the browser closer and realized i could add all the runtime folders i want. thank you for your time
GKDantas ( ) posted Fri, 15 February 2008 at 5:00 AM · edited Fri, 15 February 2008 at 5:01 AM
No problem! Here you can find some videos that I did for Carrara:
http://www.stage6.com/user/3DBrasil/videos/
Sorry some ones are in portuguese only
martial ( ) posted Sun, 17 February 2008 at 5:33 AM
For my experience ( i have used C5 and C6pro with and without transposer) if i want a scene built in Poser (still have Poser 4-5-6-7 installed) i use transposer Otherwise i use browser
GKDantas ( ) posted Sun, 17 February 2008 at 6:38 AM
Just to update I had created a channel for Carrara in Stage6:
http://www.stage6.com/Carrara
JamesRoden ( ) posted Tue, 19 February 2008 at 5:39 PM
I'm gonna throw in on this one as well, and say that you still need Transposer.
Mainly for large scenes where memory overhead is critical.  When you import stuff using the Carrara importer, you are taking the bones and all the posing into Carrara which causes a lot of memory to be used.  It's the same thing when I try to pull DAZ Studio formatted files into Carrara as well.  I can get away with multiple V3/M3 figures with Transposer as the importer, whereas I'm lucky if I can get two done without memory allocation errors in a fully built scene.
And for the record, the most characters I have pulled off in a scene are three V3's, an M3, and a Don, all fully clothed in the Mog Ruith interior, all handled through Transposer...
The image is at  www.renderosity.com/mod/gallery/index.php
Requiem "...angels fall from grace, and sometimes heroes die."
Tunnelrunners --The Complete Archive
nomuse ( ) posted Thu, 21 February 2008 at 6:15 PM
Not to mention that dynamic cloth isn't in Carrara yet.  And some of us find the Poser library system and posing dials, though clumsy, at least more familiar than Carrara's equivalent.  So Transposer can still be useful in certain workflows.
Oddly enough, I did a scene recently using both Transposer, Native import, and straight obj import.  Unfortunately, they all came into the scene at slightly different positions and scales.
JamesRoden ( ) posted Thu, 21 February 2008 at 6:26 PM
I know, that drives me nuts...I've played around with a Copy of C6 and found that if you set the Transposer scaling units to around 80-100, you can get good results versus the internal objects and vegetation that Carrara has.
nomuse ( ) posted Thu, 21 February 2008 at 6:33 PM
I sent in a bug report.  It was closed and marked "not an issue."
JamesRoden ( ) posted Thu, 21 February 2008 at 7:31 PM
Probably busy trying to con us all into buying A4 ;-)
Nate ( ) posted Tue, 04 March 2008 at 6:42 AM
Quote - Just to update I had created a channel for Carrara in Stage6:
Nice.
Wanted to see the stuff, downloaded the latest divx players.
When I click on your movie it says it is not a divx file???
I tried to watch the one about displacement in Carrara
What's updoc?
On-line portfolio / Making figurines in China / Gallery  / Video Demos
Chris1234 ( ) posted Tue, 04 March 2008 at 2:45 PM
Stage6 was shut down. How is it these videos are still there? Has anyone been able to download them still?
