Tue, Oct 22, 5:31 PM CDT
Bryce F.A.Q (Last Updated: 2024 Oct 20 11:30 am)
Subject: Volumetric light in Bryce
Roland58 ( ) posted Sat, 16 February 2008 at 10:49 AM · edited Tue, 22 October 2024 at 5:22 PM
Anybody can say me why I can't use volumetric light when there is something behind?... Example : I put a volumetric light alone in my scene, no problem, when I render the scene I can see the volumetric light, but  if I put the same light into a room for example, the light works, but NO volumetric light. It seems vomumetric light needs sun light to work, as if volumetric light was dust or smoke (see picture attached) !!! I try lot of seetings but nothing works
Thx for your help.
sazzart ( ) posted Sat, 16 February 2008 at 7:15 PM
Did you try enabling infinite & visible settings, as well gradient,  fall off settings?
~Sazzart~
Rayraz ( ) posted Mon, 18 February 2008 at 6:59 PM
It might also be that the material of the light cone triggers by the amount of light available. It could simply be brighter in an open scene because the open scene provides additional light from the bryce sun?
(_/)
dan whiteside ( ) posted Mon, 18 February 2008 at 8:14 PM
 I think that the problem is that the v-light is being shadowed. If you turn off Receive Shadows then the v-light shows up but objects inside the light don't cast shadows. Try the light setup I show here and see if that works for you. Bryce image is the light inside a cube.
Roland58 ( ) posted Tue, 19 February 2008 at 5:49 AM
Thx  a lot Dan In fact I have seen when you put a light in the scene, the default setting in materiel room  is "Light Sensitive". If I change that just as you show on your piuc and select "Basic Shading" I can see the volumetric cone of light.
Thx a lot
You can see on my pic the most realistic result...for me...
Thx
Roland58 ( ) posted Tue, 19 February 2008 at 6:05 AM
sorry for the pic...
Roland58 ( ) posted Tue, 19 February 2008 at 6:07 AM
My settings
