Quote - Hi LBJ2,
Yes, I am interested in the same info that you are. I am glad you posted that question.
cheerio lululee
Hiya Lulu
Since i know you would want this information.
The problem is solved thanks to the hardworking people in this thread ;)
She is posted in my gallery if you wanna see her:
http://www.renderosity.com/mod/gallery/index.php?image_id=1622184
The only small thing missing in the PZ2 file was a ":1" missing by the end of every line that has the word Actor in it.
A small but fatal difference.
They ought to correct it in Poser format exporter for D|S i thk.
Since my PZ2 file was generated with that utility.
Best Regards
LBJ Denmark
Look at the old posts (in Poser tech forum) concerning readscript for V3. The best way to put out pz2's is without :1, as this allows multiple characters to be staged without crossover effects. But the :1 has to be removed from everything. True without :1 then you do need to select the character first (how else is Poser to know which character? - well should be obvious if only 1 but we're talking Poser here ;-)) but as pointed out this is unlikely to be the problem here. I suspect the problem is that Daz is still putting :1 into their characters, morphs, etc., so you need it in the pz2 file. If all the numbers are missing, then Poser will use the default number assigned when the character is loaded, 1st = 1, 2nd = 2, etc., and the pz2 file can be blank and it will apply to last character selected - the way Poser worked back when readscript was invented - Poser 3 or 4 probably.
Quote - Look at the old posts (in Poser tech forum) concerning readscript for V3. The best way to put out pz2's is without :1, as this allows multiple characters to be staged without crossover effects. But the :1 has to be removed from everything. True without :1 then you do need to select the character first (how else is Poser to know which character? - well should be obvious if only 1 but we're talking Poser here ;-)) but as pointed out this is unlikely to be the problem here. I suspect the problem is that Daz is still putting :1 into their characters, morphs, etc., so you need it in the pz2 file. If all the numbers are missing, then Poser will use the default number assigned when the character is loaded, 1st = 1, 2nd = 2, etc., and the pz2 file can be blank and it will apply to last character selected - the way Poser worked back when readscript was invented - Poser 3 or 4 probably.
Hiya
But "Poser format exporter" which generated my PZ2 file, from withing Daz Studio...is a utility, to install in Daz Studio, even written by Daz. So if Daz has a ":1" in their chars, the utility to support the chars should generate a ":1" too i thk.
Do people use that utility for Poser 4-7 at all? Do it work in Poser 4-7 at all?
Best Regards
LBJ Denmark
Quote - Yes it IS a Daz thing.
Are you a Poser or D|S user? "Poser format exporter" is a utility for D|S
Maybe thats the difference about your INJ working without ":1" ?That Daz "Poser format export" utility for D|S should add it i think. But it dont
Yes I am a Poser user that's why I didn't think the one would matter.
I checked out your character face in your gallery and she is quite pretty...she has a very interesting face with a lot of character. Congrats on getting her to work in one click :)
Regards
Eshal
I'm a genetically enhanced blonde...what's your excuse? ~Eshal~
Quote - > Quote - Yes it IS a Daz thing.
Regards
Eshal
But its my own fault :) I posted this in a Poser forum, since i have a feeling there are more poser user than Daz users... not sure im right about that... but its a feeling.
And thanks to this thread.. yes one click haha.. its great i think.
Yes she has a lot of personality... maybe not the most beautiful face in the world... but very very special. Even if she is 45yo now. She still has IT ...haha.
Best Regards
LBJ Denmark
Hiya and thanks
Yes it works :) Thanks to the hardworking people in this thread ;)
She is posted in my gallery if you wanna see her.
Best Regards
LBJ Denmark
