Mon, Jan 27, 11:57 AM CST
DAZ|Studio F.A.Q (Last Updated: 2025 Jan 25 8:29 am)
Subject: How to get reflections
DigitalDreamsDS ( ) posted Sat, 23 February 2008 at 11:03 PM · edited Mon, 27 January 2025 at 11:43 AM
How do I get reflections in glass using DAZ Studio. I have tried several ways, playing with the reflection, adding images and all that.
Please help.
Akhbour ( ) posted Sun, 24 February 2008 at 5:49 PM
Could you post a WIP to clearly see what you want to do?
Normally you tweak the reflection settings in your surface tab, if you want real reflections push it up to at least 50%, you can as well use a reflection map for faked reflections, which renders faster the the real ones.
Peter
Khory_D ( ) posted Mon, 25 February 2008 at 9:23 AM
If your using reflection without adding a map be sure you have things to be reflected from every angle the reflection might show. Try it with say the mil environment or something else that will give the glass something to reflect from all around.
www.Calida3d.com
Daz studio and Poser content creators
Andrew_C ( ) posted Wed, 27 February 2008 at 5:38 PM · edited Wed, 27 February 2008 at 5:40 PM
Yes, you need something to reflect if you are not using reflection maps. You could simply put the object and cameras inside a large white sphere, or between two planes to get reflections, but something like the Millenium Environment would be better for a realistic scene. You will probably also need to add a light source. Render using the 3Delight renderer. The OpenGL renderer does not handle reflections well.
shotgung0d ( ) posted Thu, 28 February 2008 at 7:55 PM
The reflecting surface might need to be tweaked a bit. Here's some generic settings for "Real" reflections to help you get started.
Specular
Glossiness - 100%
Color - RGB 192, 192, 192
Strength - 100%
Reflection
Color - RGB 192, 192, 192 (No map)
Strength - 75 to 95%
Lighting Model
Glossy Plastic
Like I said those are generic settings for a near mirror-like reflection. Yes you will need some light and something there to be reflected. Start with those and make adjustments as needed to get the desired effect for your scene. Hope that helps.
Crios ( ) posted Fri, 13 June 2008 at 4:02 AM
Sorry, i'm a newbye, for use the mirror setting, i must keep it on the surface of reflecting object (mirror or other)?
RHaseltine ( ) posted Fri, 13 June 2008 at 2:30 PM
The material settings are for the surface you want to act as a mirror.
