Mon, Jan 13, 11:17 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: Thumbnails
rocker333 ( ) posted Sat, 01 March 2008 at 1:06 PM · edited Mon, 13 January 2025 at 11:16 AM
Hi, can anyone tell me why Poser 6 is not showing thumbnails for some products? I have a lot in Poser 6, but was told to change the prefs file, which I did, but a good many of the thumbnails are not showing up. Any help would be greatly appreciated! Thanks, Shirley rocker333
Acadia ( ) posted Sat, 01 March 2008 at 1:12 PM
You only need to change the librarypref.xml file in Poser 5.  For poser 6 if you go to "Edit" and "Preferences" you should find something about collapsing thumbnails under one of the tabs.  Pick "Never Collapse" and then save the changes.
rocker333 ( ) posted Sat, 01 March 2008 at 1:19 PM
Thanks for your reply.  I do have that checked. I am going to try reinstalling Poser and see if that helps.
Acadia ( ) posted Sat, 01 March 2008 at 1:21 PM
Don't forget to reinstall the SR patch updates too.
rocker333 ( ) posted Sat, 01 March 2008 at 1:59 PM
Did the reinstalling, didn't make any difference. I am at a loss as to what to do next.........
Jumpstartme2 ( ) posted Sat, 01 March 2008 at 2:05 PM · edited Sat, 01 March 2008 at 2:06 PM
Did you reinstall the updates as well? How about uninstalling the product and reinstalling that? You could also try creating an external runtime, or using the 'downloads' runtime..install to that and see if the thumbnails reappear.
~Jani
Renderosity Community Admin
rocker333 ( ) posted Sat, 01 March 2008 at 2:14 PM
I do have an external Runtime. I didn't uninstall, just did the reinstalling. Do you think I should uninstall it, then install it clean?
Acadia ( ) posted Sat, 01 March 2008 at 2:19 PM
You shouldn't have to uninstall Poser 6 to do a reinstall to fix things. I've never had to do that.
Did you install the SR1 and SR2 and SR3 updates?
markschum ( ) posted Sat, 01 March 2008 at 2:23 PM
libraryprefs.xml in runtime/prefs folder
<?xml version="1.0"?>
change the previewnum value , default is 100
rocker333 ( ) posted Sat, 01 March 2008 at 2:34 PM
Yes, reinstalled everything. Took some files out and it still is not showing up, quite a lot of them in each folder.........
Jumpstartme2 ( ) posted Sat, 01 March 2008 at 3:03 PM
What I meant about uninstalling/re-installing, was the product "Blackthorn Rose" for example..not uninstalling Poser 6 ;)
Also, change that value Markschum referenced above, see if any of that works :)
~Jani
rocker333 ( ) posted Sat, 01 March 2008 at 3:11 PM
Oh, okay. I did change the '200' number to 1000, as recommended. But it wouldn't stay changed. I am just going to uninstall it completely and reinstall it and see if that helps. A lot of the thumbs are not showing up, not just Blackthorn Rose's............thanks for all the advice, I do appreciate it........
nruddock ( ) posted Sat, 01 March 2008 at 3:13 PM
Attached Link: http://www.senosoft.com/
Some thumbnails have a broken alpha channel. I believe this can often be fixed by using P3DO Explorer (see attached link).
There is a free version and a paid for version (see RMP -> http://market.renderosity.com/mod/bcs/index.php?vendor=6261).
IIRC, the difference being the paid for version does bulk conversion, the free one only one at a time.
Acadia ( ) posted Sat, 01 March 2008 at 4:20 PM
Quote - Oh, okay. I did change the '200' number to 1000, as recommended. But it wouldn't stay changed. I am just going to uninstall it completely and reinstall it and see if that helps. A lot of the thumbs are not showing up, not just Blackthorn Rose's............thanks for all the advice, I do appreciate it........
1000 is too high a number. Try picking 600 or something like that. I know with Posr 5 I couldn't get it to stay with 1000.
Also make sure you go to "File" and "Save" after you make the change in the file.
rocker333 ( ) posted Sat, 01 March 2008 at 5:03 PM
What i did was forget about Poser 6, although I like it better than Poser 7, and pointed Poser 7 to my external runtime. Now the thumbnails are showing. Which bring me to why I don't like Poser 7. Sometimes it will close when I am going from one folder to the next, say going from the 'figures' to the 'pose' folders, and sometimes it will say 'building folder menu, then close.....if I don't click on it the right way........lol.........thanks everyone for your help, it is much appreciated. Another question, if I am not using the Poser 7 default characters, is it okay to delete them? Thanks again!
Acadia ( ) posted Sat, 01 March 2008 at 5:28 PM
Yes, you can delete the default characters if you don't use them.  You can also do a "minimal install" instead of a full one. I used to do that with Poser 5 and 6 when I had a smaller hard drive and didn't have room for a full install.
rocker333 ( ) posted Sat, 01 March 2008 at 5:31 PM
Okay, that is good to know. I don't use them they are just taking up space. I will delete them. Thanks!
Acadia ( ) posted Sat, 01 March 2008 at 5:36 PM
You can also compress your files to save space.  See this thread where I have given some instructions on how to do that.
http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3169372&ebot_calc_page#message_3169372
rocker333 ( ) posted Sat, 01 March 2008 at 7:47 PM
I was wondering what that compress thingy was......lol.......but I am using Poser 7 now, and the thumbs are showing up..........I just hope it doesn't close on me for no good reason.....lol....
