Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
You only need to change the librarypref.xml file in Poser 5. For poser 6 if you go to "Edit" and "Preferences" you should find something about collapsing thumbnails under one of the tabs. Pick "Never Collapse" and then save the changes.
say." - Ghandi
Don't forget to reinstall the SR patch updates too.
say." - Ghandi
Did you reinstall the updates as well? How about uninstalling the product and reinstalling that? You could also try creating an external runtime, or using the 'downloads' runtime..install to that and see if the thumbnails reappear.
~Jani
Renderosity Community Admin
You shouldn't have to uninstall Poser 6 to do a reinstall to fix things. I've never had to do that.
Did you install the SR1 and SR2 and SR3 updates?
say." - Ghandi
Oh, okay. I did change the '200' number to 1000, as recommended. But it wouldn't stay changed. I am just going to uninstall it completely and reinstall it and see if that helps. A lot of the thumbs are not showing up, not just Blackthorn Rose's............thanks for all the advice, I do appreciate it........
Attached Link: http://www.senosoft.com/
Some thumbnails have a broken alpha channel. I believe this can often be fixed by using P3DO Explorer (see attached link).There is a free version and a paid for version (see RMP -> http://market.renderosity.com/mod/bcs/index.php?vendor=6261).
IIRC, the difference being the paid for version does bulk conversion, the free one only one at a time.
Quote - Oh, okay. I did change the '200' number to 1000, as recommended. But it wouldn't stay changed. I am just going to uninstall it completely and reinstall it and see if that helps. A lot of the thumbs are not showing up, not just Blackthorn Rose's............thanks for all the advice, I do appreciate it........
1000 is too high a number. Try picking 600 or something like that. I know with Posr 5 I couldn't get it to stay with 1000.
Also make sure you go to "File" and "Save" after you make the change in the file.
say." - Ghandi
What i did was forget about Poser 6, although I like it better than Poser 7, and pointed Poser 7 to my external runtime. Now the thumbnails are showing. Which bring me to why I don't like Poser 7. Sometimes it will close when I am going from one folder to the next, say going from the 'figures' to the 'pose' folders, and sometimes it will say 'building folder menu, then close.....if I don't click on it the right way........lol.........thanks everyone for your help, it is much appreciated. Another question, if I am not using the Poser 7 default characters, is it okay to delete them? Thanks again!
Yes, you can delete the default characters if you don't use them. You can also do a "minimal install" instead of a full one. I used to do that with Poser 5 and 6 when I had a smaller hard drive and didn't have room for a full install.
say." - Ghandi
You can also compress your files to save space. See this thread where I have given some instructions on how to do that.
say." - Ghandi
