Mon, Nov 25, 6:58 PM CST
Subject: Strange 'lag' problem with Poser 7
Neyjour ( ) posted Sat, 08 March 2008 at 11:16 PM · edited Mon, 25 November 2024 at 6:52 PM
All of a sudden my P7 has started 'lagging' and I don't know why.  I'll try to explain as best I can what's going on...
I aways used to have an arrow mouse pointer when working in P7.  Now, whenever I move the pointer across my workspace, it turns into a little cross with arrowheads on each end...and then it lags for about 5-10 seconds.  This also happens when I try to select a figure from the drop down menu, or after loading something into the workspace.
It's driving me nutty!  I don't know what has happened or what's causing it.  And I certainly don't know how to fix it.  Does anyone have any ideas please?!  :(
"You don't know what we can see
Why don't you tell your dreams to me
Fantasy will set you free." - Steppenwolf
Gareee ( ) posted Sat, 08 March 2008 at 11:46 PM
Did you update your video drivers recently? I know ati drivers are causing interface issues with P7...
I just installed the new ones the other day, and am seeing some garbage.. I might need to roll back until the next release, and hopefully it'll be fixed.. if you DO find out that's the issue, report it to SM, so they can bug ati about fixing it.
Neyjour ( ) posted Sun, 09 March 2008 at 12:13 AM
Oh no!!!  Yes, I have an ATI card and I just updated my drivers yesterday!  Crap... :(
I'll send in a report.  sigh
Neyjour ( ) posted Sun, 09 March 2008 at 12:34 AM
Well, I just sent an email to Technical Support.  Don't know if it will do any good or not... crosses fingers
Oh, and I forgot to say 'thanks' Gareee!  :)
Gareee ( ) posted Sun, 09 March 2008 at 1:09 PM
I DID hear the april drivers for poser are much better, but I'm wondering if since then ati picked up another bug?
Neyjour ( ) posted Sun, 09 March 2008 at 4:27 PM
I'm not sure I understand what you mean by that.  What are "april drivers for poser"?
This is what I installed from the ATI website:
ATI Catalyst 8.3 Display Driver for Windows XP Professional/Home Edition
Is there something else I'm supposed to install specifically for Poser?
stewer ( ) posted Sun, 09 March 2008 at 4:39 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2732531
 There's a solution in this thread: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2732531
Neyjour ( ) posted Sun, 09 March 2008 at 5:05 PM
Thank you SO much stewer!!!  😄
I edited the Poser.ini file and everything is back to normal...no more lag!I didn't even have to install the 7.12 driver.  It worked just fine with the 8.3.  Yay!
David.J.Harmon ( ) posted Sun, 09 March 2008 at 6:33 PM
can someone explain more in detail what I must do to fix the display problem
David J Harmon
davidjharmon.com
Neyjour ( ) posted Sun, 09 March 2008 at 6:37 PM
Open your Poser.ini file in a text editor (eg. Notepad)
Change:
PREVIEW_OGL_OBJECT_BBOXPICKING 0
to
PREVIEW_OGL_OBJECT_BBOXPICKING 1
For me (Win XP) the Poser.ini file is located here:
C: > Documents & Settings > Compaq_Owner > Application Data > Poser 7 > Poser.ini
David.J.Harmon ( ) posted Sun, 09 March 2008 at 7:12 PM
thanks I needed that
David J Harmon
davidjharmon.com
Neyjour ( ) posted Sun, 09 March 2008 at 7:15 PM
You're welcome.  Glad it worked for you.  😄
Gareee ( ) posted Sun, 09 March 2008 at 7:55 PM
I'm still getting some oddness even with boxpicking=1
I was referring earlier to the april ati driver when it's released.
Neyjour ( ) posted Sun, 09 March 2008 at 8:00 PM
Yeah, I saw in the other thread that there's supposed to be a fix for this next month.  :)
The only oddness I'm experiencing is a very brief flicker of the cursor every now and then.  But other than that, no major problems...so far.  :)
Gareee ( ) posted Sun, 09 March 2008 at 8:16 PM
try doing an area render.. before it renders you see "ghosts" of the box that was stretched out around the area.
I'm also seeing preview lighting abnormalities.. if I get closer to a object it gets brighter, and further away it is lit less.
VERY weird.
