Forum Moderators: RedPhantom
Did you update your video drivers recently? I know ati drivers are causing interface issues with P7...
I just installed the new ones the other day, and am seeing some garbage.. I might need to roll back until the next release, and hopefully it'll be fixed.. if you DO find out that's the issue, report it to SM, so they can bug ati about fixing it.
I'm not sure I understand what you mean by that. What are "april drivers for poser"?
This is what I installed from the ATI website:
ATI Catalyst 8.3 Display Driver for Windows XP Professional/Home Edition
Is there something else I'm supposed to install specifically for Poser?
"You don't know what we can see
Why don't you tell your dreams to me
Fantasy will set you free." - Steppenwolf
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2732531
There's a solution in this thread: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2732531can someone explain more in detail what I must do to fix the display problem
David J Harmon
davidjharmon.com
Open your Poser.ini file in a text editor (eg. Notepad)
Change:
PREVIEW_OGL_OBJECT_BBOXPICKING 0
to
PREVIEW_OGL_OBJECT_BBOXPICKING 1
For me (Win XP) the Poser.ini file is located here:
C: > Documents & Settings > Compaq_Owner > Application Data > Poser 7 > Poser.ini
Yeah, I saw in the other thread that there's supposed to be a fix for this next month. :)
The only oddness I'm experiencing is a very brief flicker of the cursor every now and then. But other than that, no major problems...so far. :)
try doing an area render.. before it renders you see "ghosts" of the box that was stretched out around the area.
I'm also seeing preview lighting abnormalities.. if I get closer to a object it gets brighter, and further away it is lit less.
VERY weird.
All of a sudden my P7 has started 'lagging' and I don't know why. I'll try to explain as best I can what's going on...
I aways used to have an arrow mouse pointer when working in P7. Now, whenever I move the pointer across my workspace, it turns into a little cross with arrowheads on each end...and then it lags for about 5-10 seconds. This also happens when I try to select a figure from the drop down menu, or after loading something into the workspace.
It's driving me nutty! I don't know what has happened or what's causing it. And I certainly don't know how to fix it. Does anyone have any ideas please?! :(
