Tue, Nov 19, 11:03 PM CST
Subject: Cannot delete/remove Poser7
richardson ( ) posted Thu, 13 March 2008 at 3:32 PM · edited Tue, 19 November 2024 at 1:24 AM
I'm having the usual problems getting a new install to work. I cannot seem to find all the "hidden" data logs that store info on your last install. ie, I cannot get rid of P7 completely. I know this because it stores my prefs. I think it's storing bad installation locations too (conflicts). I've tried to install on several drives to no avail. I remove the app. I then delete 2 Poser7 temp files in Documents and Settings/myname/.. Then the datalog(install failed). Finally the e frontier file .(.program files/efrontier). Yet,,, P7 still has info on my next install. Where is the other pesky BUGger? I need a "clean" install.
pjz99 ( ) posted Thu, 13 March 2008 at 3:39 PM
See img...
My Freebies
rofocale ( ) posted Thu, 13 March 2008 at 6:36 PM
Richardson,
go to start/ run and type in : regedit
There you will find the files shown above in the pic!
Good luck
richardson ( ) posted Thu, 13 March 2008 at 8:47 PM
Thanks! I have no report on the reinstall. Not sure what the problem is yet.
svdl ( ) posted Thu, 13 March 2008 at 10:10 PM
The Poser 7 settings files can be found in "C:Documents and SettingsApplication DataPoser 7"
You'll have to delete that folder and its contents as well before reinstalling Poser 7.
My gallery   My freestuff
richardson ( ) posted Thu, 13 March 2008 at 10:11 PM · edited Thu, 13 March 2008 at 10:13 PM
Got P7 to install on a drive besides C. But,, the SR2.1 will not find it. The "CAPS" are not by me in that file search.
rofocale ( ) posted Fri, 14 March 2008 at 11:17 AM
Perhaps you should send a note to e frontier regarding this issue.
They might have a solution, who knows?!
