Thu, Feb 13, 12:10 AM CST
Subject: Is it possible to install Vue over itself?
BillyGoat ( ) posted Thu, 13 March 2008 at 4:32 PM ยท edited Wed, 12 February 2025 at 6:47 PM
Just curious - will I lose all my files?
My Poser import has gone south out of nowhere. I went to e-on and found that the you can replace the the ENV to get the Poser import running. It didn't work.
Any idea how to fix it?
Thanks
thefixer ( ) posted Fri, 14 March 2008 at 3:21 AM
I had to do a full install, not as bad as it sounds!
Assuming you have all your Vue files inside MyDocs then it is painless!
1 Place your e-on folder in a new folder called Temp or whatever, inside MyDocs.
2 Uninstall Vue from your pc.
3 Re-install Vue using it's normal parameters, i.e. MyDocs for files, Programs for system.
4 Delete the new install folder from MyDocs and replace it with the one you saved earlier in the Temp folder.
5 Job done!
this does work, I had to do it earlier when my Poser imports stopped, the pz3's would come in but weren't using any Poser shaders or textures even though I'd ticked the box!
I didn't lose anything with this method!
Injustice will be avenged.
Cofiwch Dryweryn.
