DAZ|Studio F.A.Q (Last Updated: 2025 Jan 11 12:30 am)
Did you have V4.2 loaded and selected when you applied the LoD script? It works for me, for what that's worth. You can apply the LoD yourself, if the script won't work - select V4.2, then in the Edit menu Add level of detail.... and navigate to contentdatablMilWom_v4b_68498LOD in the Studio folder and select the OBJ you want, repeating as needed.
Hi Blueblott LOD actually allows you LESS detail! The way its set up with v4.2 you get the hi-res BASE and 3 lower res versions. You can then choose to have lower res on the screen but use the hi-res when rendering. Or you can get it to use the successively lower res versions the further they are from the camera. And only send the resolutions required when rendering. The idea is to speed up the construction of a scene and/or allow more figures in a scene.
regards
prixat
Hello,
I have ds 2.0 installed along with Victoria 4.2.
in the content display I have this LOD item appear.
After checking in my "How to break code and secret cyphers" pocket book I found to my delight that this was in fact Level of detail!!
Great, I thought.. this could be the icing on the cake.
Firmly selecting LOD .......with trembling finger ...the whole program locked up.
Has anyone got this feature to work ?
Or rather whats the secret?
Looks like it could be useful.
Sorry still a newbie.
But thanks.
