Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
TOXE: Wow 8-core. I am getting one too in the summer. Now as far as the bug, I have not stumbled in to that one yet. I have been using several Macs with different configurations, and I have not see this yet. I usually start a project on the desktop then move it to my "work" HD. But then if I continue working, I can access the files just fine. I did have a project that I could no longer open, but I wrote that off as a corrupted file. Now you are not referring to "runtime" stuff right?
One thing that might help you see what is going on. Their is an application inside your Utilities folder inside your Applications folder called Console.app. Have it running in the background and clear it's log, then attempt to reproduce the issue and see if you get a clue as to why this is happening. Also you might try to check your preference files. These are XML files that can, at times, get corrupted, this although unlikely, could be a culprit also.
Is anybody also getting the wrong extension while trying to export anything out of Carrara 6.1 Pro on a Mac?
It's not a really bad bug, it's just annoying. The workaround is to learn and type the extension manually.
