Forum Moderators: RedPhantom
Are you certain the texture you're using is mapped the same way as the model? Did the model come with a texture template? Have you compared the texture template against the texture map that you have set up for the model? To me it looks as if the UVmap for the model is quite different from how the texture bitmap is laid out.
Hrm...no it was a freebie so I dont think it came with a template. This is the little guy that came with Teo and Telka here in the store. I bought the set and downloaded all the freebies from Nursoda's site. Think I will shoot him an email if I can't find a template or maybe try running UV mapper on it and see what I can see. zai • edit: Newp...no template - just redownloaded and checked, It does say use MacConverter, which I believe I already did with everything. Must have since the rest of it loads properly...the pack and the saddle, etc.
Rendo Store | Freebies | RDNA Store
yeah..I remember it, possibly as a stuffed toy, though. There's another critter something like this...be back soon, and I find it. In fact, it was called 'It', if'n I remember rightly...;)
I's by F-Wizard, and is called 'It'. The one you have is in a folder called 'digital'...and the thumbnail looks like it's striped...
I can't find the web page for the critter, but I think it was in Freestuff.
Can you point me to it? I could look at how it is UVmapped and incidentally make a template for you if you like (publish it to freebies), not a big deal for me.
edit: is this it?
http://www.klopfholz.de/nursoda/site/reipus/Reipusset.html
Here's a texture template for you:
http://www.renderosity.com/mod/rrfilelock/download.php?fileid=33590&key=5792
uploaded to freebies pending approval but you're welcome to it. PSD format.
Can you show a copy of the actual texture image reipus.jpg? I don't t see anything wrong with your material settings at all, so I think it is either that the jpeg has become damaged, or somehow the model's UVmap has gotten damaged.
also while I don't think this is it, see what happens if you make bump strength 0.
The reason our bump strength numbers are different is that it is dependent on what your preferred measurement unit is set to, and is converted internally before it is displayed. Mine is set to Inches, yours looks more like it is set to, uh, some unit I can't figure out (doesn't seem to be yards or meters but something quite large).
Err - you know, I did not actually look at the original texture resolution, that was a silly goof. The proportions in my version are WRONG. However as you have just shown, Poser can squeeze or stretch the texture into the neighborhood of the right proportions, it's just a pretty bad idea to do so. I will go cancel my freebie upload since it's not a good idea to play with the texture proportions this way.
It seems to me something is simply wrong with the reipus.jpg file that you have. My advice is re-download the original and see if that version of file works correctly.
Must be something wrong with the file, although it worked when transferred to your doc. The new download did exactly the same thing. Opening that and cutting and pasting it into a new doc didn't help either. Ah well...I will leave it be until later this afternoon and see what else I can think of, save rendering in p4! zai
I am kind of stumped. Maybe the Mac version of Poser simply does not like non-square textures, that is all I can think of. I'd contact EF/Smith Micro.
I've run into this problems several times and there is a simple fix. Just open the texture in a graphics program and resize it to slightly UNDER 4000 pixels for the largest side - 3998 usually works for me but if it doesn't try 3900 - that always works for me. Then resave the texture. It should now apply properly.
"Do not meddle in the affairs of cats, for they are subtle and will piss on your computer." -- Bruce Graham
Oh that's a good point, this tex is 4500x3000. You're probably right, although I'm actually surprised it renders for me at that resolution with no change - maybe Zai is running P6.
Anyone had this problem? I've opened the texture jpeg and resaved it. It looks fine. I don't see any weird nodes attached to it in the material room, just a image texture and a bump. I've even changed the jpeg name to be sure it isn't cached somehow and made it a different color to be SURE it was picking up the right skin. All I get is rainbows. I think it's got to be something in Poser but danged if I know why it's doing this. It's like the skin texture has its headers saved wrong and possibly turned weird or sized wrong. Ain't he cute though? I love this whole set!
