Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
I have been having some bugs with batch processing. HOWEVER - IT REALLY IS UP TO 6 TIMES FASTER. I did a couple of Aerysoul items this morning in about 42 seconds a pop. Color me impressed!
EDIT: also adding in morphs works fantastic! all of the aerysoul item shave the kewl movement morphs and what not.
I am now a shill for XD3, as it rocks! Too bad I have spent like 100 bux on it.
If the morphs are built in, not body handles, I believe it works. for a test I looked at M3's Arab robe by PW to see what it had, lots of morphs. Converted to Ug using the add morph function. I used the lowest quailty setting since I was more concerned with the morphs at this time. Result: All of the morphs were put in and could be acessed by the body or body part. does that help?
Not impressed by it, had several issues with A4 (real) morph not showing up in the clothing I batch converted.
Poserverse The New Home
for NYGUY's Freebies
Quote - Not impressed by it, had several issues with A4 (real) morph not showing up in the clothing I batch converted.
Right, nothing batch has worked for me so far. I am thinking that will need a fix :)
Then again, since it was converting so fast... I didn't mind. I did all of AS Eclipse to A3 with morphs in about 10 min.
The only reason why I purchased XD was cause I needed to convert several gloves form other figures and found XD to be the better at it than WW2 or Clothing Converter.
Question -- its not clear to me reading the XD 3 site whether you can fit clothing to a morphed figure, like you can with Wardrobe Wiz 2. Just to be clear, I'm talking about spinning body dials on a V3 for example and then clothing through XD so it fits the morphed body.
I do have XD 2 and can recommend it highly for conversions between figures. I bought WW 2 because of the fitting function, and I can recommend that program very highly as well. If XD 3 had fitting I would get the uprade because its always better to have two tools for a problem.
Quote - Question -- its not clear to me reading the XD 3 site whether you can fit clothing to a morphed figure, like you can with Wardrobe Wiz 2. Just to be clear, I'm talking about spinning body dials on a V3 for example and then clothing through XD so it fits the morphed body.
At this point no. You have to buy a seperate pack for putting morphs into clothing and currently they have only V4 available. I am assuming that V3 / A3 and the rest are coming later.
Quote - Hi Gazukul,
Have you succeeded in tranferring custom morphs?. I can convert the clothing, but every time I try to transfer a morph ( not V4's FBM , those work fine) I'm getting an errormessage and the program stops.
Bopper.
To experiment - I just spawned a morph target into a clothing item (AS Elven strapped) with magnets and successfully transfered it over.
I have had it bomb on other stuff I was transfering morphs, on a few items I had to drop out some of the channels in order for it to work. Like on the Eclipse leg item, there were a couple of knee morphs that would not go.
Let me know if there is something you want me to try specifically.
This has been a great improvement, especially now there's the welding options. Had so many problems with 2.0 about cracks or breakage in the mesh. Also adding the morphs is so easy and I love the batch option.
I'm having trouble with I think the joint paramaters? around the neck and crotch area. Don't know too much about how to fix this in poser even after looking at PhilC's tutorials.
If anyone is kind enough to give directions for a noobie, My V4 will thank you for her new Utilze clothes:)
Don't have it and probably never will. Have tried everything and can not put anything in my cart. Different browsers firewall off, yes I'm admid of the computer. Have emailed the vendor many times and the last email from him was what browser are you using. Told him and that's the last I've heard. Was going to get the one for Sydney but will just have to either use WW or make my own. But I'm glad other folks are able to use it.
If you haven't solved your morph question this might be of some use: After you have the clothing, convert quality, from figure and to figure selected take a look at the Transfer Morphs section, Click on the Choose Button then select those you want. Then click in the checkbox otherwise the morphs won't transfer. Then click on Convert Clothes.
Anyone have any reviews? They added the ability (with purchase of additional morph packs) to include figure morphs. Does it do as good a job as Wardrobe Wizard? Is it better for some things?
thanks
