Is it lcd or crt, BB? I just recently switched to a lcd from crt, and you DO see a big difference, but since crts are being phased out, and crts are almost impossible to find/buy anymore, I'd just go with lcd stuff now, because odds are, that's all we'll ALL be using in a year or two.
From that image, it looks like the poser figure had much more lighting then the guys to her left.. not how dark "overall" they are then she is.
I agree w/ Gareee, she looks slightly lighter than the guys on her left.
For comparison purposes, I'm using a ViewSonic, 22-inch, with a 700:1 contrast ratio.
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
To me it's not the fact that she's lighter than everyone else(maybe she just started going to the beach), it's hard to see much detail due to the distance she's been posed from the camera. Also another thing that makes her look out of place is the fact that she too sharp when compared to not only the guys close to her but also the sand and the shell,rock or peice of paper that in the image is closer than she is seems to be blurred more than her.
Had to edit when I reread that it wasn't a skin shader but shaders used for scenes. Please disregard the part about not seeing enough detail of her skin.
She looks fine to me, but I'm using a 20" CRT.
I think what may also throw off the image a bit is she's on the very tall side. :)
I know she's closer to the camera, but scaling is a bit off. (Minor nit)
The shader looks good to me though.
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
Skin-color is individual for each person. Same for "light response" in a specific range (highlights, reflection, roughness (bump)). Beach or not.
For me the image shown is allmost perfect, bagginsbill. Checked on (calibrated) CRT-monitors and LCD's. I checked also against some other photographs.
By the way: Poser-images usually have to mutch black. One more reason why a poser figure put into a photograph seldom looks good without color-correction.
I think the skin shading looks great, very convincing. I'm okay with the skin tone being lighter (those lads are very, very sunburned).
My monitor is LCD, and the contrast ratio is so high nothing looks the same as it used to.
For reference here's another crop of the original photo (I took it in Hawaii) - check out theuntanned dude on the right.
I made here somewhere in between. I'm looking for normal skin right now, not beach bum skin :)
Although that will be an option.
BB: I read a few tips abotu the high contrast ratio on lcds...
First they say to turn it down to about 10%
Then they also recommend seeing if the monitor also has a gamme setting for r/g/b, and then turning THOSE also down to about 50% as well. Rhis will get th emonitor down to a more traditional level, it will extend the life of the monitor, and also it'll reduce eye fatigue as well.
I find my lcd MUCH easier to see them my old crt next to it, bu tif I leave it at it's default settings, I need sunglasses.. LOL!
Here's the quote from the tech about it:
"Another thing I look for in a monitor is capability of low brightness. For a programmer, too-high brightness is a big problem. Many LCD monitor's are ridiculously bright and cannot go down to 100cd/m2 (at 100cd/m2, also called "print-level" a white screen is about as bright as holding a paper page in a well-lit room). Anything more than that is quite straining for the eyes, especially at night. Turning the brightness to 0, and the contrast to about 25, I get the "paper effect" with this monitor, although blacks are not as deep as I would like. It does better than most monitors, but not nearly as good as my older Sony 19" SDM-HX93 LCD which had an amazing backlight adjustment.
UPDATE: I discovered a way to lower the brightness in addition to the brightness/contrast controls. Go to "Color setting" in the menu, and turn down all 3 RGB colors; I set Red to 70, Green to 70 and Blue to 62. This lowers the brightness considerably, so I do not have to reduce the contrast too much to achieve the low brightness setting I am after for easy-on-the-eyes late night coding sessions.
You can take the RGB colors all the way to 0 resulting in a black screen; it's an awesome brightness adjustability!
This trick may work on other monitors too, please comment if you have the chance to try it on Samsung, LG, Viewsonic, or other monitors. "
Viewing on a 17" iMac 5, dual core Intel 2.16 gHz running ATI Radion x1600:
Great light integration with the scene, though she appears much sharper / crisper / "more in focus" than the guys on the left. Her skin has the same characteristic waxiness as the mental ray Non-Physical SSS skin shader, which is to say that the specularity is exceptionally smooth and the skin tone perhaps too little orange or red.
To me the skin just looks great, people can have lighter skins than others, so the difference in tint doesn't bother. The only thing that shows me she isn't real, is her hair. But you asked for her skin and that's just perfect. Even on my low-budget 1000:1 Belinea 22 inch TFT monitor.
Bopper.
PS. Glad to hear you're still working on your skin shader program, it has been a little bit silent about it, but I know you're very busy with your new job.
The skin gloss looks very good and natural to me.
Same as the guy's on the left.
I understood thats whats it about.
And I use a hmmmm...a monitor.
You know, one of those old cast iron, coal fueled monsters.....same as my comp btw.
:biggrin:
I am not a complete idiot, some
parts are missing :)
To go to my home page,
click the banner below.
Check my freebies on a regular base, click the banner below.
I appreciate the insights about the hair, unmatched blur and imperfect shadow angle, but I'm not really trying to fool you with this comp. If I were, I'd be doing some blurring in photoshop, or start with a higher res background photo. Rather, I just threw in the beach photo as a backdrop to give a sense of what I'm trying to create. I threw the hair on because she is hard to look at bald.
As to the super tan those guys have, I can do that no problem. The issue I'm solving is what if your figure is NOT super tanned? Everybody has seen great "real skin shader" style renders with heavily speckled and darkened skin. But how many light-skinned realistic renders have you seen? Take a look at the super un-tanned guy sitting behind her. He has no skin detail, and he's whiter than she is. Why does he look real? Why do renders look fake unless you go towards the supertan look? That's what I'm trying to get to here.
My goal is that a user can take my lights and my shader, and they know what they're going to get, without having to do a bazillion test renders.
By the way, I used no GI here, but there is AO on the skin. This is just two lights, one infinite, and the other is a procedural IBL I made with nodes, not a picture.
**I'm going to throw in my 2cents. On the first pic, I have to agree that the only thing that didn't "blend" in with the rest of the photo was her hair. But I also understand there's not much that can be done with hair models. Hence why I avoid them when I can. grin
On the close up of her, her skin looks lightly tanned and the lighting blends just as well as the first image. Even the hair blends better.
May I say I am highly impressed? Because I am. And this is looking at the images on an old Compaq 17".
I find it very convincing for my part. I know you are always looking for the little beettle under the rock, but i think you have obtained very great results here ^^
Quote - Take a look at the super un-tanned guy sitting behind her. He has no skin detail, and he's whiter than she is. Why does he look real? Why do renders look fake unless you go towards the supertan look? That's what I'm trying to get to here.
It's because the shadows at the Poser figure is to "flat", not dark enough on the "deeper" parts. The shadow does not "model" the character.
Speaking freely, there are two things that are bothering me: Like Adp001 said, the shadows. The shadows on a sunlight day are much darker. The sharp edges of the shadows are allright , that's what you expect from sunlight. I think the AO could be stronger to make the shadows in the deeper parts darker.
That's one.
Second: I really think the skin of the body looks perfect, but the skin of her face, looks rather flat to me, just like she used to much powdercoat-makeup, perhaps you can give it a more oily appearance, which won't look strange on a beach.
I hope I didn't sound too hard, I have great appreciation for your work, it's always a pleasure to read your threads in the node-cult.
Bopper.
To go off at a slight tangent from everyone else (nothing new there then) ...her calves, what we can see of them, knees, and lower thighs look absolutely great, but above that it goes a little "flat" for me. One thing I'd like to see especially is more detail on the hands, maybe by ramping up the bump map a little?
The liver is evil - It must be punished.
Interesting. That is entirely controlled by the IBL, because the shadow parts are no longer lit by my infinite (the sun).
So I need some more variation and contrast in the IBL.
I was wondering exactly how much light the "sun" contributes versus the environment.
I zoomed in on this person's back. We have shadows from the bikini string.
The ratio of the shadow to the lit is 82%, i.e. the shadow is 82% as bright as the lit part.
In my render, I had a shadow brightness of about 70%. So I made TOO MUCH shadow, at least for the parts that are open to the sky and sand.
I agree I need to get the AO working on the "deeper" shadows. I'm beginning to suspect Poser is having problems with the AO node, not really producing anything.
Here is side-by-side, with AO and without AO, so you know what is caused by AO.
The high-contrast IBL has left the face looking strange to me. Is it wrong?
Slinger, I agree about the face - I think I need to use a specular map. Human faces are oily.
Try to use a seperate specular map on any parts. Human skin has zones reflecting light different. This is also the case for bumpmaps (inner arm, outer arm, for example). Ask a makeup-artist working in a photo studio to get an idea on which parts powder is a must ;)
With AO, the bottom part is nearly perfect.
By the way: Make sure no intersection occurs. In reality the tissue on the legs will be compressed/deformed, building a deep, sharp fold (with dark shadow). You can't get the same effect without deforming the mesh or fixing this parts via postwork.
Of course you can adjust all sorts of things, but the point is it's supposed to be idiot proof.
Here is Jessi.
On the left is default. On the right is after clicking VSS.
Left, default. Right, VSS.
Left, default, right VSS.
Notice VSS knows not to touch her clothes. It only modifies skin, eyes, etc.
On the left, V4 after clicking her !All_Natural MAT pose. This is more than just color maps and bump maps, it is a whole shader. On the right, VSS.
On the left, using the "Ultimate" shader that comes with Poser 7. On the right, after clicking VSS.
Sydney's skin color is wrong. The one-click won't give good results. Need to adjust tone in the shader to work with this color map.
Quote - I think you need more sss - more red in the shadow regions.
Jeff,
That's sort of funny.
I have been told over and over that I overuse the SSS effect, that my renders are too red. People are constantly asking me for how to make characters more pale. Face_off's tools will give you red and speckly characters and so will my shader, if you set it for that. Nobody has an answer for "white" people. So that's what I'm trying to get here.
I have a dial for the SSS amount and for the color - we can crank it up if you like.
This is just my opinion of course.
I think the highlight sizes could be larger overall. My experience is that skin, even moisturized, casts larger/brighter highlights, unless oil or water is on the surface. Much in the way color on the face can be defined by maps, so can oil of the face. But I think generally, highlights are more spread out/scattered.
I worked as a make-up artist for many years. The skin in the renders looks great. But it reminds me of when a body that has been oiled is then powdered trying to reduce the shine. Just a suggestion to try slightly larger/brighter highlights.
Just trying to be helpful. Looks great regardless.
-Anton, creator of Apollo Maximus
"Conviction without truth is denial; Denial in the
face of truth is concealment."
This is a friend of mine. The picture was taken with her facing a sunny window. Sliding glass doors, on the other side of the room, light her back.
She did moisturize prior to the shoot since we knew her back would be showing. Where her face is powdered, the surface area highlight there is really strong. Powdered skin, like other matte surfaces, absorbed more light.
Anyway, I hop that illustrates what I was trying to express.
Anton's image show lots of highlight but they don't have that glassed look as the poser images seem to have. Is that something that just can't be helped? They look better than most I see. Seem that fresh varnished look is popular with merchants product mats and you see it quite often in the galleries.
So yours compared to that common denominator are fantastic.
Hi Anton,
Of course this is adjustable by the user, but I want to get it right for out-of-the-box.
Now I'm going to ask you to look closely at the real highlight and my shader highlight, above.
Ignoring the difference in skin tanning, they look pretty much the same to me with respect to highlight size and distribution.
Soon I'll have some documentation written, and I'll share the VSS files with you all.
Then we can collaborate on the perfect skin shader.
The beauty of the Versatile Shader System (VSS) is that you can edit ONE material zone for skin, and then click once to synchronize all the zones, despite the fact that they have to have different color maps and bump maps and so on.
This means that you can do a lot more iterations in less time. Change a node or two, click once to synchronize and render. It takes less than one second to apply your new shader nodes to all zones, all figures.
Anton I looked again at your next post with the photo.
"Facing a sunny window" is not at all the same as facing the sun, isn't it?
She is not actually being lit by the sun directly, right? Rather, she is being lit by the reflected light from outdoor objects that can be seen through the window.
This is like using one of those big umbrella diffusers. Of course this means that she is being lit by an "area" light, not a point light, so the highlights are very broad.
The camera exposure was obviously set to receive a lot more light. If you had the camera correctly set for shooting outdoors, I doubt we'd see any highlights on this indoor scene at all - they'd be too low.
I'm now experimenting with indoor light response. I stupidly put in some transmapped hair and let Poser go render with 4 ray-traced point lights. It is stuck now and won't cancel. Otherwise I'd show you the indoor highlights all spread out nicely.
In your beach reference the skin looks "oiled"/wet. This is typical and believable in such a scene.
Anthons picture shows an indoor scene. We recognize this because there is no sky. So we don't await hard shadows, because we know skin isn't only lit by the sun (direct light mixed with indirect light resulting in soft shadows and wide highlights). Something our brain recognizes automatically.
It isn't possible to have one single type of shaders for any light setting. But something to select different light-response types and/or environments with one click may satisfy most needs.
I didn't work too hard on morphing her to match - V4 morphs aren't that sophisticated and I gave up after about half an hour. I want to work on lights and shader, not morphing.
I'm having a heck of a time trying to get Poser lights to produce the same pattern as the two windows did. We don't have area lights. I'm using 4 point lights, 1 infinite, and 1 ibl right now.
Will probably have to go to 12 point lights and IBL.
I'm using point lights because I don't have to aim them. After I get the positions right, I'll make a spotlight setup as well. The trouble with point lights is that you must use raytracing and raytraced shadows against transmapped hair is deadly.
I'm putting together some sample scenes and shaders to go with it. One of the hardest problems is realistic outdoor composition. Here is a sample.
Also, I have a brand new 24" Samsung SyncMaster monitor with a freaking 10,000 to 1 contrast ratio. I'm a little concerned that what looks great to me (now) doesn't look so great to you.
So, how does it look?
(Click for full size)
