Sun, Feb 2, 9:19 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Subject: Problems exporting....
FCLittle ( ) posted Mon, 05 May 2008 at 12:53 AM · edited Thu, 23 January 2025 at 3:05 PM
Has anyone ever encountered problems when exporting....I'm just trying to export the basic Jesse model and every time I do the head malfunctions (it loads but it's not all there).   I did change the head a little and I morphed the body, but I don't see why this should have any effect on it.  Anyone know how to fix this?
BeyondVR ( ) posted Mon, 05 May 2008 at 3:35 AM
Could you explain what you mean by "exporting."  Are you saving the figure to the library?  Or are you exporting an OBJ to another program?
John
FCLittle ( ) posted Mon, 05 May 2008 at 11:33 AM
I'm exporting it from Poser into another program, and each time the head malfunctions....
lesbentley ( ) posted Tue, 06 May 2008 at 1:07 AM
What version of Poser are you using? Did you use the Grouping Tool to create any new gropes?
FCLittle ( ) posted Tue, 06 May 2008 at 1:33 AM
I'm using Poser 6.  I didn't make any new groups.  I changed the head by playing with it in the face sculpting area, and I morphed her body (not a specific morph, I just played around)....when I export it as a 3ds I export as a single frame, I don't uncheck anything, and I save them as object groups, and every time so far the head malfunctions.
This is so confusing....
Morkonan ( ) posted Tue, 06 May 2008 at 1:45 PM
I'm probably the absolute last person anyone should ask about Poser technical problems.. Well, aside from a few very dead people from the 1600's.  However, I've known simple "scaling" to be a culprit sometimes.  If you scaled the head/neck to something other than 100%, try creating a morph for that, dial back up to 100, enable the morph and then try to export again.
Like I said, it's dangerous to follow my advice and could result in the destabilization of several third-world countries.  But, it's all about how desperate you are, isn't it?  ;)
