Tue, Feb 11, 1:53 AM CST
Subject: Can I export V4 from Poser 7 to Bryce 6.1?
dyret ( ) posted Thu, 15 May 2008 at 6:38 AM · edited Tue, 11 February 2025 at 1:52 AM
I have tried a search. Can someone please point me in the right direction? Is it actually possible to export V4 from Poser to Bryce 6.1?
Incarnadine ( ) posted Thu, 15 May 2008 at 6:48 AM
It should still work as a wavefront object export  (.obj) from poser as a static mesh.
dyret ( ) posted Thu, 15 May 2008 at 6:52 AM
ok- thank you. not shure what a static mesh is. I guess i will find it when I try to use export. thank youn again.
rstar ( ) posted Thu, 15 May 2008 at 10:42 AM
If I'm not mistaken, doesn't DAZ Studio open Poser files into it's program fromt any content sources that it recognizes in its content searches?
If so, if you use the DAZ/Bryce link in Bryce , load the file in DAZ Studio and pose it as you like then link back to Bryce, it should load automatically in Bryce.
dan whiteside ( ) posted Thu, 15 May 2008 at 12:14 PM
 While using the D|S bridge has it's problems you can just do a "Save As..." from Poser, then load Bryce, hit the D|S Icon from the Bryce Create palette and then in D|S use the Import command to open the saved Poser .PZ3. Quit D|S and the figure along with the textures should load right in.
tom271 ( ) posted Thu, 15 May 2008 at 1:12 PM
quote:  *"you can just do a "Save As..." from Poser,   "
  • you mean save the figure from Poser as a .PZ3 file format somewhere on the side and import it from D/S..??
dan whiteside ( ) posted Thu, 15 May 2008 at 1:52 PM · edited Thu, 15 May 2008 at 1:55 PM
 That's what works for me Tom. There's several things D|S doesn't import, like magnets and dynamic cloth/hair.
Edit: I haven't tired this with D|S 2 or Poser 7.
chohole ( ) posted Fri, 16 May 2008 at 4:21 PM
I work with V4 in bryce all the time, no problems.
Only slight problem is if you want to tweak the pose, because then you have to go back to poser an redo the pose, then re-export the obj. I don't use D/S
The greatest part of wisdom is learning to develop  the ineffable genius of extracting the "neither here nor there" out of any situation...."
Sambucus ( ) posted Sat, 17 May 2008 at 2:12 AM
Dont forget that once you have the object in Bryce, click on Objects/Break D/S link in Bryces top menu.  If you dont, if you return to D/S youll lose the first object.
That, of coourse, is if you can get the link to work at all.  I can`t.
dyret ( ) posted Sat, 17 May 2008 at 6:57 AM
Than you all! Over at DAZ forum I didnt get an answer! LOL
Sambucus ( ) posted Sat, 17 May 2008 at 8:04 AM
Getting an answer is one thing you can reiy on here, although you may not understand it if it`s from me LOL.
cowbjo ( ) posted Mon, 19 May 2008 at 12:54 AM
Don't know if this will meet your needs, but
http://brycetech.com/
has a tutorial on eporting Poser to Bryce and also directions to another useful site.
dyret ( ) posted Sun, 25 May 2008 at 5:51 AM
so i can open poser files in studio? that would save a lot of trouble for me. studios content menus are a right pain!!!!
