Fri, Jan 31, 10:31 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: Help on shadows & antialiasing in P7?
gagnonrich ( ) posted Mon, 12 May 2008 at 2:25 PM · edited Fri, 31 January 2025 at 10:27 AM
I just ran into a few problems on an image rendered in Poser 7.  I've got the slider settings on automatic cranked up to a pro render (one tick away from the most far right setting).
  1. The shadows are too hard and solid. I don't know what settings to change to soften them.
  2. P7 is hiding antialiasing from me. The setting in the render menu is only for antialiasing the preview window. From poring through the manual, it appears that the only way to set antialiasing on a render is to do it from the animation menu which is a bit counterintuitive. Is that what's required? The only place this seems to be a big problem is when I rendered with depth mapping. Although the background is blurred, there are a number of jagged edges clearly visible. I can always render the background as a separate element that I can blur in Photoshop, but it would be nice to have Poser do the work for me.
3. Is there a Python script for centering two objects together? It is such a laborious process moving lights and cameras where I want them in a large image.
My visual indexes of Poser content are at http://www.sharecg.com/pf/rgagnon
adp001 ( ) posted Mon, 12 May 2008 at 2:39 PM
Set shadow intensity in the light palette. Shadows are indiviually set for each light.
IsaoShi ( ) posted Mon, 12 May 2008 at 3:05 PM
gagnonrich
Point 1 - in my P7 (for Mac) it's the Shadow Blur Radius setting (for each light that is casting shadows).
Point 2 - in my Render Settings it's the slider bottom right labelled Post filter size and Post filter type (I generally use size 2, and Gaussian because I like the sound of it).
Point 3 - sorry, I know nothing bout that
adp001 ( ) posted Mon, 12 May 2008 at 3:58 PM
Point 3: Parent one object to another (light to a prop, for example). Set X, Y and Z to 0 for the parented object and it will move to the center of his parent.
stewer ( ) posted Mon, 12 May 2008 at 4:09 PM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3146482
 If you scroll down in this thread, there's some info about anti aliasing: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3146482
MistyLaraCarrara ( ) posted Tue, 13 May 2008 at 10:15 AM
Quote - Point 3: Parent one object to another (light to a prop, for example). Set X, Y and Z to 0 for the parented object and it will move to the center of his parent.
Thanks.  This is a great tip.   I can't wait to try it with lights.
I've been putting lights inside of lamps and its a tough job to align manually.
Cheers,
Lara
Miss Nancy ( ) posted Tue, 13 May 2008 at 6:44 PM
gagn, let them know if any of these tips help.  in general, don't change "post filter"
from 1 unless using textures that are very low-res or jagged.
gagnonrich ( ) posted Tue, 13 May 2008 at 11:10 PM
I haven't had a chance to try these tips out yet, but will hopefully have some time tomorrow. Thanks for the helpful advice.
I was surprised that high render settings didn't automatically take these factors into account.
Miss Nancy ( ) posted Wed, 14 May 2008 at 10:56 AM
yeah, from what I've heard, anti-aliasing was an old term from the late 80s, when folks were
using monochrome CRT monitors and trying to do smooth graphics.  FFRender was designed
to produce smooth edges on all objects in a scene, so that the user no longer hadda worry
about it.  IMVHO the term "anti-aliasing" has thus become somewhat of a misnomer
in regard to modern 3D apps, hi-res LCD monitors and OS with sub-pixel rendering.
AFAIK the usual way users get jagged edges on objects is when they export a render
with a blank background, then try to delete said background colour in APS or PSP.
Latexluv ( ) posted Wed, 14 May 2008 at 5:07 PM
Online Now!
The dpi of your output image matters where 'jaggies' are concerned. For posting in the gallery, I usually render my images at 120 dpi. For print quality images, you have to crank that up to 300 dpi which makes for a long render but produces a picture that will look really nice when you print via your own printer or take it to a photo processor for nifty things like t-shirt transfers.
Weapons of choice:
ockham ( ) posted Wed, 14 May 2008 at 7:05 PM
On the centering, try my SnapTo.  It's the script I use more than any other,
because I'm usually working in a large scene.
http://ockhamsbungalow.com/Python/SnapTo.zip
Also a variant
http://ockhamsbungalow.com/Python/SnapToCam.zip
My python page
My ShareCG freebies
Anniebel ( ) posted Thu, 15 May 2008 at 6:59 AM
Antialiasing in P7 is controlled by the 'Pixel samples' slider --> "more sample per pixel provides greater geometry-based detail and antaliasing" <-- direct quote from the help tip on the bottom of the Render box.
I have found a setting of about 7 stops the jagged edges & isn't too soft.
The best & most beautiful things in the world cannot be seen nor touched... but felt in the heart.
Helen Keller
My Gallery                       My Freebies                        My Store
RubiconDigital ( ) posted Thu, 15 May 2008 at 6:09 PM
Antialiasing is not a throwback to the 1980s that doesn't apply anymore. On the contrary, it is extremely important in obtaining smooth edges and diagonals in renders. It's also of critical importance when it comes to clean alpha channels and compositing. It has nothing to do with auto smoothing of objects, such as that which Poser performs.
Dpi has nothing to do with antialiasing, or file size, or render time. This is one of those "facts" that keep getting passed around the Internet and only confuse people. Dpi is only relevant when printing. It does not affect how an image looks on screen or how long the render takes.
Miss Nancy ( ) posted Thu, 15 May 2008 at 8:29 PM
well, there you have it, rubi.  they don't call it anti-aliasing anymore.  they call it by various other terms now, depending on rendering app, e.g. "pixel samples" or "shading rate" in P7/PP, where
the CPU does progressively more calculations per screen pixel to make it look more accurate,
according to the optical properties of the posersurfaces and lighting.
anti-aliasing was just pixel-averaging IIRC.
RubiconDigital ( ) posted Thu, 15 May 2008 at 9:21 PM
Well, the technique is still called antialiasing. Some programs will have it labelled as pixel samples or some such, but it is still antialiasing by another name.
